is SCOM compatible with CUCM 4.X MCS-7800 server?
Hi All,
I am asked if we can install the SCOM client on the MCS Server where we have the Cisco Callmanager Cluster and Unity, anyone know if SCOM is compatible with the MCS servers? any impact?
Andres Cerda
1 ACCEPTED SOLUTION
Re: is SCOM compatible with CUCM 4.X MCS-7800 server?
It's not supported
Third-Party Platform Agents Running with Cisco CallManager
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/prod_bulletin0900aecd800f8572.html
For Unity open the correct doc depending on version:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
Supported Hardware and Software, and Support Policies for Cisco Unity Release X.X
I believe it's also not supported on Unity.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
It's not supported
java
java
Thanks sir!!
Andres
504
