Is Simultaneous Registration of SIP and SCCP for CUCME Possible?
I am attempting to get SIP registration working on a CUCME router with some SCCP phones already registered. Has anyone been able to get this working?
Re: Is Simultaneous Registration of SIP and SCCP for CUCME Possi
Yes, this is definitely possible. SIP phones are not configured under "telephony-service" the same way SCCP phones are. Instead you use the "voice register global" config stanza and also enable the "registrar" configuration under voice service voip > sip.
See this link for information on setting up SIP under CME.
http://www.netcraftsmen.net/resources/blogs/sip-endpoints-in-cisco-communications-manager-call-manager-express-x-lite.html
I was using X-Lite in the example, but the concept is the same.
So, summary:
SIP: "voice register global"
SCCP: "telephony-service"
Just as an FYI. When the phone boots it looks for its config files in this order:
SEPDEADBEEF0001.cfg.xml
SIPDEADBEEF0001.cfg.xml
So, if you were trying to convert a phone that used to be SCCP, check the flash to make sure the SEP version of the config file is removed.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
I've attempted to remove the SEPABBCCDD00111.cfg.xml file from flash. When I enter the command "create profile" under the [voice register global] section I get a message such as:
"can't find SEPABBCCDD00111.cfg.xml" and then I find this same file in flash:.
It seems that the file keeps popping up. Would you know the reason behind this?
252
