Is TEHO/LCR from a CME to a CUCM registered MGCP Endpoint possible?
Could anyone point me to a document that shows how to use a PSTN MGCP endpoint registered to a CUCM  for a breakout by a CME device which is peered to the CUCM via either h323 or SIP.
Hopefully the pic below explains better including the dial-peer at the CME.
I have already configured the dial peer to the CCM as below
dial-peer voice 9 voip
description outbound
destination-pattern 9T
session target ipv4: <IP of CCM Publisher>
dtmf-relay h245-alphanumeric
I also have a working Route Pattern in the CUCM to dial to PSTN via  "9.!" pointing to the MGCP endpoint via a Route List.
Currently I get the following message :
"Your call cannot be completed as dialed, please consult your directory"
Thank you for your help in advance
Naushad
1 REPLY
Green
I reckon that should work OK.
On your CUCM H323 gateway page  back to the CME look at the CSS for incoming calls
Does this contain a partition that has a 9.! route pattern in it
Also does the same gateway allow all significant digits for the incoming call
Alex
Regards, Alex. Please rate useful posts.
317
