Community Member
Is the 6941 VPN capable?
Hello, I'm wondering if the 6941 phone is VPN capable when located at a users home. All documentation points to the 7900 and 8900 series.
Thanks.
Everyone's tags (1)
I don't think those support built in VPN client but as things change often the best way to check if by following these steps for your CUCM version.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_5_1/secugd/secuvpn.html#wp1051453
Supported Devices
You can use Cisco Unified Reporting to determine which Cisco Unified IP  Phones support the VPN client. From Cisco Unified Reporting, click Unified CM Phone Feature List. For the Feature, choose Virtual Private Network Client from the pull-down menu. The system displays a list of products that support the feature.
For more information about using Cisco Unified Reporting, see the Cisco Unified Reporting Administration Guide.
Community Member
Thank you for your response.
502
