is the port 8443 required in order to accessUnified Communications Manager
e.giron
Level 4
Level 4
I would like to just type the ip address/ccmadmin as I previously did, is there a way to not have to remember to type the https://ccmip:8443/ccmadmin
chadlincoln
Level 3
Level 3
As long as it is UCM 5 or higher, you can just type the IP address with nothing else and get there. Just put in 192.168.1.1 hit enter and you should get there. Version 4 made you use the https as well as the ccmadmin, but 5 and higher, just the IP will work.
Please rate if this helped.
