Is there a CLI command to check DLU's?
available and used?
This is version 7.1.5
Thanks!
Tracee
Hall of Fame Super Red
Hi Tracee,
There are no commands via cli related to the
license/DLU's on 7.x. There are some new cli commands
on 9.x related to licensing/ELM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/9_0_1/CUCM_BK_C3A58B83_00_cucm-cli-reference-guide-90_chapter_0100.html
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Best you could do is try looking via SQL into these tables:
licensedistributionused (362) licenseinfo (394) licenseserver (359)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/datadict/7_1_3/datadictionary_713.pdf
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
122
