Community Member
Is there a conversion table for DLUs to CUCM 9.x licenses?
During the upgrade process from pre-9.0 releases to CUCM 9.0 and later, ELM is installed and lets you convert your licensing from the DLU model to the UCL/CUWL licensing model.  This worked fine for the upgrades that I have already done, but now I am trying to plan how to allocate unused DLUs to the other license classes for the dozen or so additional clusters that I need to migrate.  ELM does NOT appear to have an offline mode where you can enter a number DLUs and then come up with an acceptable allocation of UCL/CUWL/TP rooms beforehand.
Is there a formula somewhere that I can use to do this planning in advance of the actual upgrades?
9
Everyone's tags (3)
Community Member
Unofrtunately, that function has been removed from LCU in the current version and all previous versions have been removed from Cisco.com
Purple
Hi ,
I agree with you[+5]. You need to run LCU 9.1.2  online for generating csv file and  send to licensing Team.
You do not get option of Conversion worksheet and RUN Compliance Check.
You can also refer the link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/uct/9_1_2/CUCM_BK_U0AE00F5_00_uct-admin-guide.pdf
regds,
aman
Community Member
Hello!I have the same problem
Hello!
I have the same problem.
And when I sent ELM request to license team after upgrade to 9.1, they are doesn't convert unused DLUs to Enhanced and Basic.
Now I'am trying to make sure that they have written and convert unused DLUs, but so far without success.
Purple
Hi, this should not be the
this should not be the case.
You should receive mail from Cisco licensing team /Product Manager asking for the confirmation on conversion of Unsed DLUs to Enhanced/Basic.
regds,
aman
Community Member
Hi, Aman. No, they don't ask
Hi, Aman.
No, they don't ask me how I want.
And else one. They generate license from PLU 9.1.2 report only. But after made this report, customer added some devices and report after upgrade from ELM was different.
And now they don't want generate additional license file. It is very frustrating.
Purple
HI, that should not be the
HI,
that should not be the problem.
You can generate new LCU report and share with licensing team. They can accordingly generate license file.
Also, whenever u add new phones in call manager 9, u need to follow the same process and have  another lic file.
regds,
aman
Community Member
So, what about unused DLU?
Purple
Are you sure the LCU report
Are you sure the LCU report shared contains unused DLUs? If that is there, then, u can ask licensing team to revert on conversion of unused DLUS.
regds,
aman
Community Member
This was not consistent with
This was not consistent with my experience.  The license team used the LCU report, without the allocation of the unused DLUs, in spite of my request being very clear about that NOT being what I needed.  It took almost a month to resolve with multiple escalations in the process.
Community Member
This was NOT consistent with
This was NOT consistent with my experience
Community Member
I did NOT mark this as a
I did NOT mark this as a correct answer, nor was it consistent with my experienced.
Community Member
I just went through a
I just went through a particularly painful exercise with the Cisco licensing group migrating a CUCM 8.6 system to 9.1.  They required the following:
1) License request from ELM
2) Cisco SO# for upgrade order
3) Output of the LCU utility
4) ESW/UCSS contract number
In spite of carefully spelling out exactly what I needed was in the ELM license request, they issued a license which covered, all the licenses contained in the LCU report.  Unfortunately, the LCU report covered a dozen or so different clusters, which are isolated from each other and could not share an ELM.  After almost a month of working with the licensing group, I finally got it straightened out.  In the process, I grabbed this information from the ELM 9.1 migration license calculator:
License Type                  DLUs Required
CUWL Professional          12
CUWL Standard               11
Enhanced Plus                 9
Enhanced                         6
Basic                                4
Essential                          0
Telepresence Room        11
Purple
thanks for sharing the info.
this is the process which we need to follow.But I did not understand about LCU report  in which u are referring to dozen clusters or different clusters .
When u run LCU report, u enter the credentials of single cluster.
regds,
aman
Community Member
The version of LCU that I ran
The version of LCU that I ran allowed multiple clusters and credentials to be input.  I work for a SP and we did this for several of our managed service clusters for different customers on a single report that we used to get our contract entitlement correct.  The problem became that although I asked for license for only one of the clusters on the report, GLO issued all licenses for all clusters to a single ELM.  Unfortunately for me, the multiple clusters are isolated from each other and could not share an ELM instance, so unwinding this back to the proper state became the painful, time-consuming part of the process.
Purple
Understood.I think u should
Understood.
I think u should have conveyed multiple cluster info to GLO.
[+5] for sharing the info.
regds,
aman
Community Member
I did, and also conveyed what
I did, and also conveyed what I wanted done with the unused DLUs in the LCU report, but they ignored both pieces of information and issued a single license with just the allocated DLUs for all clusters and threw away all unused DLUs.
1801
