01-21-2008 12:42 AM - edited 03-15-2019 08:19 AM
It doesn't seem like Cisco offer a true Operator console for UC, espcially 4.x. Suggestions are to use the 7961 along with 7914 expansions, but if you read the QA of the 7914 it clearly states this is not an operator console.
For UCE and UC6.0 there's the 7931G which is similar to 7961+7914 but am curious how come Cisco haven't come up with a proper console.
Am I missing something?
Nick
01-21-2008 05:38 AM
Hi Nick,
You are not missing anything! There is no Hardware based Attendant Console available for CCM (any version). Like many of todays newer PBX releases the focus is on Software Application Attendant Console's like;
If you are looking for a Hardware setup that does simulate (somewhat) the industry standard type AC then the 7961 with 7941 is probably the desired choice. The 7931G is OK but does have many limitations and is not as pleasing to the eye with paper labels etc.
Hope this helps!
Rob
01-21-2008 05:54 AM
This product is what many customers are using -
ARC Console enterprise for Callmanager and ARC Console express for Call Manager Express
http://www.arcsolutions.com/AsiaPacific/Products/index.html
The intelligence of the attendant console is normally in the application itself, not the physical layout of the device. Therefore the consoles will generally work with a range of handsets.
Cisco resells this product.
01-22-2008 02:11 AM
Thanks Rob and cameron for the info provided. Will check our ARC
02-04-2008 09:56 AM
Hi There
please do let me know if you need any more information on this please do let me know - I believe some of your other locations are already using the Arc product
02-05-2008 02:34 AM
I seem to be struggling in getting install guides for this - about to start an install with CUCM 6.0. So if you could provide that or point me in the right direction.
Thnx
05-06-2008 05:35 PM
Hi there - sorry I missed this message earlier.
If you still need the installation document for Arc Enterprise for CUCM 6.0, let me know and I'll mail it over to you
05-07-2008 12:33 AM
Can u mail me the installation and configuration guide for Arc Enterprise for CCM 4.2,5.1 and 6.0. My id is sadiqkareem@gmail.com
Thanks in advance
