Is there a way to change the font size on a 7942g display?
As it stands now, when we pass through caller id, it appears as (+16021234567).  The problem is that when the call is active, the box displaying the caller id and the call timer shows (+160212345...
This has become a problem for some of our end users.  Does anyone know if we can edit the caller id display to be smaller so that the full number shows?
Thanks...Jason
Everyone's tags (4)
No way to change the font or size that's displayed on the phones.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks, I figured as much.
Silver
Different firmware versions have changed this text size a bit.  You could try a few different firmware versions to see if any of them work.
Silver
It looks like the last 2 digits are being hidden.  You could change the inbound call id to strip the leading +1.
348
