Is there a way to enter mutiple Product Authorization Keys for Call manager Licenses
I have to enter licenses for my call manager.  The vendor sent my mutiple sheets with product aithorization keys.  Is there a way to submit multiple keys with Cisco instead of doing it one by one.
Re: Is there a way to enter mutiple Product Authorization Keys f
If there's a ridiculous large amount of them, you can try raising a case with TAC Licensing team where you enter all the details, and you provide all the PAK codes. They should be able to provide you with one large license file.
You can contact your vendor/reseller for assistance doing so if you can't do this step yourself.
Hope this helps,
Cedric
Thanks Cedric
154
