03-22-2016 11:18 AM - edited 03-18-2019 11:53 AM
I am trying to create a phone template with more than 5 lines. We have the 8811 throughout our network and it has 10 buttons on the face, I just kind of figured it was a shame if you couldn't use more than just the 5 to the left. I tried to create a template that had 6 lines but it gave me an error when the phone tried to register. According to this: https://quickview.cloudapps.cisco.com/quickview/bug/CSCus85518 it is a bug present in our current firmware. It doesn't specifically say you can have more than 5 lines if I upgrade them to 11, but it does say known fixed releases. I just want to make sure that I can actually have more than 5 lines before I decide to upgrade the firmware.
Thanks in advance.
Solved! Go to Solution.
12-08-2017 10:37 AM
I created a new phone button template, set the option on the device, I can configure more lines now but it does not show on the phone. Any one else having trouble?
03-15-2023 07:35 AM
I am having the same problem with the 8851. Active Load sip88xx.11-7-1-17
I can build a button template and program 10 DN's, but only 5 show on the display.
I have set the Enhanced Line Mode. Didn't change anything.
03-15-2023 07:48 AM
It is now working. I have to unplug and plug back in the phone and it work great, all 10 line are showing up.
06-18-2018 10:02 AM
We are running sip88xx.12-0-1SR1-1 and when I enable Enhanced Line Mode - I do not see the ability to "Add a new DN" when modifying the buttons. I do the ability to add Speed Dials - but not actual DNs.
03-07-2018 08:59 AM
System version: 10.5.2.11900-3
Cisco 8841
sip88xx.12-0-1SR1-1 |
We tried adding 6 lines. Created 6 DN template
Result: 6th line does not appear - Device: "Partially Registered"
It appears th elines will not carry over to buttons on right side of display
03-07-2018 09:11 AM
Hi John,
Did you install the newest device package for you CUCM? And I'm not talking about a specific phone firmware, but the whole package.
When you install it, and you go to the device page configuration, you'll find a setting named: Line Mode.
So just set it to be: Enhanced Line Mode. Save & Apply the configurations and it should work.
03-22-2016 11:55 AM
This is not currently possible, such is only possible at this time on the 78XX series
