Community Member
Is there a way to run Cisco Unified CM Assistant Configuration wizard again in CCM 7.1(3)?
I had issues when running Cisco Unified CM Assistant Configuration wizard for the first time in CCM 7.1(3). Is there a way to run it again?
Thank you
Marcos
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Is there a way to run Cisco Unified CM Assistant Configurati
Hi Marcos,
Here is the actual reference
You can use the Cisco Unified Communications Manager Assistant Configuration Wizard only once. The feature verifies the number of times that the configuration wizard has been run (zero or 1). If the configuration wizard has been run once, the summary window automatically displays. The summary window displays the details and status of the configuration wizard that was previously run. If the configuration has not been run, the configuration process continues.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmfeat/fsipma.html#wpxref39049
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Hi Marcos,
Cheers!
Rob
Community Member
Thank you Rob
165
