Is there a .zip IP Phone Services SDK named 8.5(1)?
8.5(1) has a IP Phone SDK per release notes below
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/8_5_1/ipphoneservicessdk.html
But I don’t see a .zip file for 8.5(1) SDK at below location (I’m looking for latest multidirectory.asp from 8.5(1)SDK)
http://developer.cisco.com/web/ipps
or is the .zip file named 7.1(2) IP Phone Services SDK.zip the most recent?
Everyone's tags (6)
Yes, that is the most recent one. In case you dont get what you need in that zip, please reach out to Cisco Developers ( either over forum or Developer TAC case ) to see if you can get one.
GP.
Pls rate helpful posts !!
I was getting a XML Parse 4 error on phone display. Found I had increased the number of records per page beyond 32.  Easiest way to see this was to http://ipphone and go to Console Logs and view the Parser Error on phone.
Why the multidirectory.asp code doesn't state 32 is the maximum value....
7965 Phone Console Log File
6563: ERR 19:49:19.211144 JVM: Startup Module Loader|cip.http.ae:? - listener.httpSucceed: http://10.101.240.25/firmdirectory/multidirectory.asp?action=list&id=-1
6564: ERR 19:49:19.212763 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Exception: Too many 'DirectoryEntry' elements in '/CiscoIPPhoneDirectory : occurs=33+ maxOccurs=32 (line=129)
6565: NOT 19:50:23.012144 CDP-D: PHY 1 --> LINK IS DOWN
We modified this from 32 to a higher number, has to be 32 or less
Original Multidirectory.asp from the SDK
                var ALL_DIRECTORIES_PHRASE = "All Directory Search";
                var ALLOW_ALL_USERS_SEARCH = false;
                var MAX_LIST_SIZE = 32; // Max number of users per page
0ur modified version of multidirectory.asp
                var MAX_LIST_SIZE = 64; // Max number of users per page
564
