Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Is there an OVA template for CUCMBE6000?
Trying to determine how 6000 installs on a C series...    I see this OVA template:
http://docwiki.cisco.com/wiki/OVA_Template_Details_for_Unifed_CM_Release_8.5    Use the 1000 user.  Then for Unity, do you create another OVA template and machine for it?
VIP Super Bronze
Re: Is there an OVA template for CUCMBE6000?
Yes you create a separate VM. There is a 1000 mailbox OVA for Unity Connection as well: docwiki.cisco.com/wiki/OVA_Template_Details_for_Unity_Connection_Release_8.5
Thanks Jonathan. I actually opened up a PDI case and low and behold I got Jamie. He said the BE6k is basically the same load for CUCM. So use the 1000 use OVA for CUCM and the CUC you listed below. Load the servers, configure as normal. Just keep within the specs stated in the design guide such as Nodes and users. ☺
382
