is there any way to collect CUCM's cpu usage in the past weeks?
like what we can do in IOS with "show proc cpu history".
No, and please post under the correct section, this is Video Over IP
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
ok moved to IP telephony.
Hall of Fame Super Silver
You can look at the serviceability reports which show historical reports for CPU usage, etc. These are available under serviceability page on CUCM.
HTH,
Chris
Hi Oak,
If you want to look at CPU usage for some specific time frame in the past then you can collect the RisDC Perfmon logs for the required duration from that server using Real Time Monitoring Tool and then open them with Perfmon tool of your PC and get the CPU / memory usage for all the processes for that time frame.
Manish
480
