06-01-2012 03:20 AM - edited 03-16-2019 11:26 AM
Hi All,
I am not a Cisco engineer but I would like to know if I am being given the correct information. If a client calls us on our external number for example, 0161 123 2000 my understanding is that number can be routed through to the device with the number 2000.
Is there any way we can route the call made to 0161-123-2000 to a device with a different number such as 3000.
06-01-2012 03:43 AM
Yes you can do that. What platform are you running? CCME or CUCM. You can use either translation rules or translation pattern
Pls rate useful posts
06-01-2012 03:58 AM
Thanks for your reply. I'm not sure which platform we are using but is translation rules/pattern available on both?
Do you have any further information on how to implement that?
06-01-2012 04:01 AM
It depends on what platform you are using..I can help you with the configuration but need toknow what platform you are using..So if you can get the details of the platform and the configuration on the router then this is quite easy to do
06-01-2012 04:08 AM
Thanks I'll find out. What information do you need to know about the configuration of the router?
06-01-2012 04:57 AM
the running configuration..
on the router you will type
'sh run'
Then let me know the external number(s) you want to convert to internal number( I also need to internal number(s))
06-01-2012 06:50 AM
Hi, The numbers we are calling in on is: 0161 333 5800 to 0161 333 5869
The internal range is: 2400 to 2469
So for example, if we wanted to dial 0161-333-5806 we want that to route to 0161-333-2406
Current configuration : 9599 bytes
! Last configuration change at 11:35:50 GMT Fri Jun 1 2012
! NVRAM config last updated at 12:56:58 GMT Thu May 31 2012
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
hostname welsp482-hydecheshi-2197721
boot-start-marker
boot-end-marker
card type e1 0 0
no logging console
enable secret 5 $1$lGDC$A2sExqr4De9rt5YQuItH/0
--More-- no aaa new-model
clock timezone GMT 0
network-clock-participate wic 0
no ipv6 cef
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip host WEL-CCMSERV-01 172.16.2.10
ip host WEL-CCMSERV-02 172.16.2.11
isdn switch-type primary-net5
--More-- !
voice-card 0
dspfarm
dsp services dspfarm
application
global
service alternate default
license udi pid CISCO2921/K9 sn FCZ14307232
hw-module pvdm 0/0
redundancy
--More-- !
controller E1 0/0/0
pri-group timeslots 1-30 service mgcp
controller E1 0/0/1
class-map match-any af43
match access-group name af43
class-map match-any af42
match access-group name af42
class-map match-any af41
match access-group name af41
class-map match-any ef
match access-group name ef
class-map match-any af21
match access-group name af21
class-map match-any af12
match access-group name af12
class-map match-any af31
match access-group name af31
class-map match-any af13
--More-- match access-group name af13
class-map match-any af32
match access-group name af32
class-map match-any af23
match access-group name af23
class-map match-any af11
match access-group name af11
class-map match-any af33
match access-group name af33
class-map match-any af22
match access-group name af22
class-map match-any be
match access-group name be
class-map match-any drop
match access-group name drop
class-map match-any besteffort
match ip dscp default
class-map match-any realtime
match ip dscp cs5 ef
class-map match-any priority
match ip dscp cs4 af41 af42 af43
class-map match-any cs1
match access-group name cs1
--More-- class-map match-any cs2
match access-group name cs2
class-map match-any cs3
match access-group name cs3
class-map match-any cs4
match access-group name cs4
class-map match-any cs5
match access-group name cs5
class-map match-any cs6
match access-group name cs6
class-map match-any cs7
match access-group name cs7
class-map match-any missioncritical
match ip dscp cs3 af31 af32 af33 cs6 cs7
class-map match-any transactional
match ip dscp cs2 af21 af22 af23
class-map match-any general
match ip dscp cs1 af11 af12 af13
policy-map mark
class ef
set ip dscp ef
--More-- class af41
set ip dscp af41
class af31
set ip dscp af31
class af21
set ip dscp af21
class af11
set ip dscp af11
class cs5
set ip dscp cs5
class cs4
set ip dscp cs4
class af42
set ip dscp af42
class af43
set ip dscp af43
class cs3
set ip dscp cs3
class af32
set ip dscp af32
class af33
set ip dscp af33
class cs6
--More-- set ip dscp cs6
class cs7
set ip dscp cs7
class cs2
set ip dscp cs2
class af22
set ip dscp af22
class af23
set ip dscp af23
class cs1
set ip dscp cs1
class af12
set ip dscp af12
class af13
set ip dscp af13
class drop
drop
class be
set ip dscp default
policy-map etm-WelspunCorp
class realtime
priority 1536
police 1536000 conform-action transmit exceed-action drop
--More-- class priority
bandwidth remaining percent 40
random-detect dscp-based
class missioncritical
bandwidth remaining percent 39
class transactional
bandwidth remaining percent 16
class general
class class-default
policy-map shape-etm-WelspunCorp
class class-default
shape average 3400000 13600 0
service-policy etm-WelspunCorp
--More-- !
interface Loopback0
description VzB Management IP address
ip address 10.0.5.65 255.255.255.255
interface GigabitEthernet0/0
description welsp482-hydecheshi-2197721 WelspunCorp Port,Ckt:w0x73599
bandwidth 3400
ip address 152.183.21.146 255.255.255.252
ip nbar protocol-discovery
duplex full
speed 10
no cdp enable
max-reserved-bandwidth 90
service-policy output shape-etm-WelspunCorp
interface GigabitEthernet0/1
description welsp482-hydecheshi-2197721 LAN
ip address 10.0.5.69 255.255.255.254 secondary
ip address 172.16.15.1 255.255.255.0
duplex full
speed 100
service-policy input mark
--More-- !
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/2/0
interface FastEthernet0/2/1
interface FastEthernet0/2/2
interface FastEthernet0/2/3
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
--More-- interface Vlan1
no ip address
router bgp 65109
no synchronization
bgp log-neighbor-changes
redistribute connected
redistribute static route-map static-bgp
neighbor 152.183.21.145 remote-as 65000
no auto-summary
no ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
no ip http server
no ip http secure-server
--More-- !
ip route 10.0.5.64 255.255.255.248 Null0
ip route 172.16.15.0 255.255.255.0 GigabitEthernet0/1 172.16.15.2
ip route 192.168.4.0 255.255.255.0 GigabitEthernet0/1 192.68.232.11
ip route 192.168.230.0 255.255.254.0 GigabitEthernet0/1 192.168.230.11
ip route 192.168.232.0 255.255.255.0 GigabitEthernet0/1 192.168.232.11
ip access-list extended af11
ip access-list extended af12
ip access-list extended af13
ip access-list extended af21
ip access-list extended af22
ip access-list extended af23
ip access-list extended af31
permit ip any any
ip access-list extended af32
ip access-list extended af33
ip access-list extended af41
ip access-list extended af42
ip access-list extended af43
ip access-list extended be
ip access-list extended cs1
ip access-list extended cs2
--More-- ip access-list extended cs3
ip access-list extended cs4
ip access-list extended cs5
ip access-list extended cs6
ip access-list extended cs7
ip access-list extended drop
ip access-list extended ef
permit udp 172.16.15.0 0.0.0.255 any
ip sla 300
icmp-echo 152.183.21.145 source-ip 152.183.21.146
request-data-size 64
tos 112
owner PPM_MCPA_RP-WGTNGE01
frequency 300
ip sla schedule 300 life forever start-time now
no cdp run
route-map static-bgp deny 10
--More-- match tag 999
route-map static-bgp permit 20
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager redundant-host 172.16.2.11
ccm-manager mgcp
--More-- ccm-manager music-on-hold
ccm-manager config
mgcp
mgcp call-agent 172.16.2.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 172.16.2.11 identifier 1 priority 1 version 6.0
sccp ccm 172.16.2.10 identifier 2 priority 2 version 6.0
sccp
sccp ccm group 1
--More-- associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register Cheadle-VG-CONF
associate profile 2 register Chealde-VC-XCOD
switchover method immediate
switchback method graceful
switchback interval 30
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
--More-- codec g729r8
codec g729br8
maximum sessions 4
gatekeeper
shutdown
privilege exec level 1 traceroute
privilege exec level 1 ping
privilege exec level 1 show configuration
banner motd ^C
* Warning *
* THIS DEVICE IS PART OF A PRIVATE NETWORK *
* DISCONNECT IMMEDIATELY IF YOU ARE NOT AN AUTHORISED USER ! *
* Unauthorised access is prohibited *
--More-- * And may be punishable by law *
* This device is monitored for unauthorised access *
^C
line con 0
exec-timeout 5 0
password 7 030752180500
line aux 0
exec-timeout 30 0
password 7 070C285F4D06
line vty 0 4
exec-timeout 30 0
password 7 1511021F0725
logging synchronous
login
length 0
transport input telnet
scheduler allocate 20000 1000
ntp update-calendar
--More-- ntp server 146.170.67.132 prefer
ntp server 146.170.125.133
end
welsp482-hydecheshi-2197721#
welsp482-hydecheshi-2197721#exit
06-01-2012 06:57 AM
I forgot to mention we are using: CUCM v7.1.3a
06-01-2012 07:26 AM
Hi Anthony,
You can see the required config examples in this good Tech note;
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801c43f6.shtml
If you are routing in a 1 to 1 pattern ie; 5800 to 2400, 5801 to 2401 etc. you can use
wildcards as in the example. if not you will need "specific" patterns
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
06-01-2012 12:42 PM
Rob +5 point for the excellent document...
Anthony,
The link above explains in detail how you should configure this...
In your case you need to create a xlation pattern
58XX
called party xfor mask:24XX
so 5806 will be xlated to 2406 and 5809 will change to 2409 etc...The last 2 digits will remain the same.
But you need to ensure that the partition of your xlation pattern is in the CSS of your gateway. You also need to ensure the CSS of your xlation pattern (58XX) has access to the partion of your internal numbers
