Community Member
ISDN 0x829A - Non-selected user clearing
Hi all,
Suddenly our incomming ISDN calls stopped to work. In the caller side I can hear a long ringtone and after a while I receive a busy signal; on the called side nothing happens(no ringing)
I attached the debug output (q921,q931) can anyoane help me with an idea what is happening?
As I saw the voice gateway is disconnected by the telco, I looked after the cause code 0x829A but it's not realy clear for me the meaning of the: The destination is able to accept the call. However, the destination rejects the call because the call is not assigned to a user.
Oszkar
Hall of Fame Super Gold
Re: ISDN 0x829A - Non-selected user clearing
Hi, can you configure "isdn tei-negotiation preserve" then reboot the router ?
0x829A is not an error in itself, it's just a message used to tell to all devices on the S/T bus that one call has ended, your router recieves because there is some mess going on with TEIs.
Community Member
I added and rebooted but the situation is the same.
Here is the current bri config:
interface BRI0/3/1
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
end
Oszkar
Can you remove 'isdn tei-negotiation first-call' and try again, take another trace ? In your previous trace, the calling number is given twice, very strange.
Community Member
Hi Paolo
Here is the current config and the debug output is attached.
interface BRI0/3/1
no ip address
end
What is on the other side of the BRI?
The description for this disconnect cause they're sending is this:
The destination is capable of accepting the call but rejected the call
because it was not assigned to the user.
Sounds like a configuration issue on the other side of the BRI.
-nick
Community Member
On the other side is the Telco...
I cannot make much sense of this.
I only see a normal disconnect, but:
- switch tries to talk to multiple TEIs that should not be there.
- calling number is duplicated, never seen that happen.
I suggest you disconnect the NT phisically from the pair and leave it as that for 5 mins, if that's not enough please log a fault with telco.
Community Member
I disconnected the NT and tested again after 10 min but the situation it's the same.
I will contact the telco..
Thanks for the effort!
Oszkar
1356
