ISDN BRI and CCM issue
HI all,
recently i tried to configure an ISDN connection with CallManager and it works fine but i'm stuck in something and thanks for ur previous posts by the way
I have a range of number from my SP like:
from 555501 to 555509 and i want that a predefined IP Phones like extension 4000 to use a specific PSTN number for inbound and outband Call and with an anology from the FXO conf i set up the:
Destination-pattern 9T for outband call
and
Connection plar opx 4000 for the inband
BUT with the BRI how it can be done?
Thanks in advance for all
  • IP Telephony
Green
Re: ISDN BRI and CCM issue
You can configure the BRI either as MGCP or H323
If H323 then configure a dial-peer pots with direct inward dial then a voip to fwd the number directly to ccm
If MGCP Just configure proper CSS and incoming settings for Voice Port
thanks for your reply but if the user want to use a specific number as his personnel PSTN number i mean for example if DN 4000 want only to use the PSTN number 555022 as the outband call ?
Hi is anyone there :) and thanks again for ur post Sir.
106
