ISDN BRI in Spain CME 2801 Issue
I am trying to install a 2801 CME router with VIC2-2BRI-NT/TE onto telefonica supplied BRI Circuits. I cannot get layer 2 up. their circuits are setup as Point to point is their anyway to get the CME to work with point to point? I have already set the Interfaces with point to point setup but this still does not bring layer 2 up. below is a debug ISDN Q921 and errors.
*Jun 2 19:57:42.163: ISDN BR0/1/1 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 0 tei 0 ces 255 ev 0x6F
Jun 2 19:57:19.135: ISDN BR0/2/0 Q921: User RX <- SABMEp sapi=0 tei=0
*Jun 2 19:57:19.135: ISDN BR0/2/1 Q921: User RX <- SABMEp sapi=0 tei=0
*Jun 2 19:57:19.151: ISDN BR0/1/0 Q921: User RX <- SABMEp sapi=0 tei=0
*Jun 2 19:57:19.155: ISDN BR0/1/1 Q921: User RX <- SABMEp sapi=0 tei=0
Barcelona_CME#sh isdn stat
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x80000003
Barcelona_CME#debug isdn q931
debug isdn q931 is ON.
*Jun 2 20:07:24.743: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 6178
*Jun 2 20:07:24.747: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 933010414
Barcelona_CME#
*Jun 2 20:07:30.747: ISDN BR0/1/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Barcelona_CME#
Ian
  • IP Telephony
Re: ISDN BRI in Spain CME 2801 Issue
I have recently configured a BRI in Madrid wth the same provider.
The most important is probably the TEI config. See below our config :
Interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
If it doesn't work, please post you running config.
Thank you - I have tried setting Static-TEI to 0 and my layer 2 comes up but then still cannot dialout
below is an output of a call with static TEI set to 0 where we juat cannot make a successful call.
ISDN BRI0/2/1 interface
dsl 5, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
Active dsl 5 CCBs = 0
Total Allocated ISDN CCBs = 0
*Jun 3 12:37:58.867: ISDN BR0/2/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 6178
*Jun 3 12:37:58.871: ISDN BR0/2/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 933014014
*Jun 3 12:37:58.871: ISDN BR0/2/1 Q931: TX -> SETUP pd = 8 callref = 0x06
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '6178'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '933014014'
Barcelona_CME#
*Jun 3 12:37:59.035: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x86
Cause i = 0x82E404 - Invalid information element contents
*Jun 3 12:38:25.423: ISDN BR0/2/1 EVENT: process_bri_call: call id 0x8007, called_number 933014014, Guid C91C4CAC8016 speed 0, call type VOICE, bchan -1 clng_num 6178
*Jun 3 12:38:25.423: ISDN BR0/2/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 6178
*Jun 3 12:38:25.423: ISDN BR0/2/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 933014014
*Jun 3 12:38:25.423: ISDN BR0/2/1 Q931: TX -> SETUP pd = 8 callref = 0x07
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jun 3 12:38:25.599: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x87
Barcelona_CME#
*Jun 3 12:38:25.599: ISDN BR0/2/1 EVENT: process_rxstate: ces/callid 1/0x8007 calltype 2 HOST_DISCONNECT_ACK
Ian
Good news for layer 2 ;-)
Have you tried incoming calls?
It could be a problem with line coding or number/type presentation, channel selection...
Please send a show run, it will be easier to debug...
Fred
Hi Fred,
Below is a edited output of the run config
trunk group 1
carrier-id Telefonica
description BRI Trunks
hunt-scheme sequential both
translation-profile outgoing 2
voice-card 0
voice translation-rule 1
rule 1 /^933436161/ /6161/
voice translation-profile 2
translate calling 2
voice translation-profile Default
translate called 1
interface BRI0/1/0
no ip address
shutdown
isdn send-alerting
isdn sending-complete
isdn skipsend-idverify
isdn static-tei 0
trunk-group 1
interface BRI0/1/1
no ip address
shutdown
isdn send-alerting
isdn static-tei 0
trunk-group 1 5
interface BRI0/2/0
no ip address
shutdown
isdn send-alerting
isdn static-tei 0
trunk-group 1 10
interface BRI0/2/1
no ip address
isdn static-tei 0
voice-port 0/1/0
cptone ES
voice-port 0/1/1
cptone ES
voice-port 0/2/0
cptone ES
voice-port 0/2/1
cptone ES
dial-peer voice 1 pots
description Inbound PSTN Dial Peer
translation-profile incoming default
incoming called-number 6161
direct-inward-dial
dial-peer voice 10 pots
trunkgroup 1
description outbound all calls BRI
destination-pattern 0T
dial-peer voice 99 pots
destination-pattern 0093
port 0/2/1
prefix 093
telephony-service
no auto-reg-ephone
load 7941 TERM41.7-0-3-0S
max-ephones 30
max-dn 150
ip source-address 10.10.92.1 port 2000
url directories http://10.10.92.1/localdirectory
url services http://10.10.92.5/voiceview/common/login.do
url authentication http://10.10.92.5/voiceview/authentication/authenticate.do
user-locale ES
network-locale ES
time-format 24
dialplan-pattern 1 61.. extension-length 4
voicemail 6100
max-conferences 4 gain -6
moh moh1.wav
web admin system name admin password cisco
web admin customer name cmeadmin password administrat0r
dn-webedit
time-webedit
transfer-system full-consult
night-service day Sun 00:00 23:59
night-service day Mon 09:00 19:00
night-service day Tue 09:00 19:00
night-service day Wed 09:00 19:00
night-service day Thu 09:00 19:00
night-service day Fri 09:00 19:00
night-service day Sat 00:00 23:59
create cnf-files version-stamp 7960 Jun 03 2008 09:41:23
debug isdn q931 when dailing the spanish speaking clock on tel 093
!Barcelona_CME#
*Jun 3 14:03:43.287: ISDN BR0/2/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 6178
*Jun 3 14:03:43.287: ISDN BR0/2/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 093
*Jun 3 14:03:43.287: ISDN BR0/2/1 Q931: TX -> SETUP pd = 8 callref = 0x15
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '093'
Barcelona_CME#
*Jun 3 14:03:43.463: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x95
Ian
The call is getting rejected by the carrier, and the cause code they send back to your router is:
So one of the information elements that the router is sending in the outgoing SETUP message is not correct. My guess is that the Bearer Capability is not correct. From your debugs, the bearer capability in the ougoing setup is 0x8090A2, which decodes to Voice/Speech call (u-law). Because the switch-type is Basic-net3, I think the call should be A-law instead (0x8090A3).
Try setting the compand-type to alaw under the voice port.
voice-port 0/2/1
compand-type a-law
ISDN Bearer Capability Values are defined here:
http://www.cisco.com/en/US/customer/docs/ios/12_3/debug/command/reference/dbg_ap2g.html#wp1003938
Michael.
I agree with mowuor...
That's what we configured in Madrid...
Fred
Hi Michael,
perfect answer we are now able to make successful outgoing calls.
I only noe have a problem with the incoming now.
the telco is sending me the following 933436xxx and this is translated to an internal extension 6XXX however the call is unsuccessful.
*Jun 3 14:42:44.715: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8 callref = 0x26
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Channel ID i = 0x82
Preferred, B2
Calling Party Number i = 0x0183, '00447740937963'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '933436164'
Plan:ISDN, Type:National
*Jun 3 14:42:44.727: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xA6
Channel ID i = 0x8A
Exclusive, B2
*Jun 3 14:42:44.743: ISDN BR0/2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xA6
Cause i = 0x8081 - Unallocated/unassigned number
Barcelona_CME(cfg-translation-rule)#
*Jun 3 14:42:44.843: ISDN BR0/2/0 Q931: RX <- RELEASE pd = 8 callref = 0x26
*Jun 3 14:42:44.847: ISDN BR0/2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA6
Ian
Hi Ian,
If dial-peer voice 1 is intended to be used for inbound calls, then change the incoming called-number statement from 'incoming called-number 6161' to 'incoming called-number .'
Let us know how this works.
Michael.
We had origionally done that and set it to 6161 to see if it would work so in both instances we cannot get incoming calls.
show voice translation-rule is correct
and test voice translation-rule matches also.
Ian
1188
