ISDN BRI Issue
I am currently testing callmanager 7 with a new service provider switch, however I am having issues with BRI interfaces.
I am unable to make a call on an ISDN BRI port under MGCP control (works fine as H323)
The debug message on Q931 is
*Mar 11 17:33:55.383: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x09
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x0081, '2005'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '749810'
*Mar 11 17:33:55.443: ISDN BR0/1/0 Q931: RX <- SETUP_ACK pd = 8  callref = 0x89
        Channel ID i = 0x8A
                Exclusive, B2
*Mar 11 17:33:55.447: ISDN BR0/1/0 Q931: TX -> STATUS pd = 8  callref = 0x09
        Cause i = 0x82E2 - Message not compatible with call state or not implemented
        Call State i = 0x01
*Mar 11 17:33:55.575: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x89
*Mar 11 17:33:55.579: ISDN BR0/1/0 Q931: TX -> STATUS pd = 8  callref = 0x09
        Cause i = 0x82E0 - Mandatory information element missing
        Call State i = 0x01
*Mar 11 17:33:55.595: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x89
        Cause i = 0x82E5 - Message not compatible with call state
*Mar 11 17:33:55.715: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x89
However the Debug on the old existing Service provider is
*Mar 11 17:17:35.471: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x01
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
*Mar 11 17:17:35.691: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x8A
                Exclusive, B2
*Mar 11 17:17:36.047: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8  callref = 0x81
        Progress Ind i = 0x8482 - Destination address is non-ISDN
The Only difference I can see is that the new system sends an Setup ACK message. However I am unable to ascertain what information is missing. Does anyone know if there is a setting I can change in the Service Parameters that needs to be changed????
Many thanks in advance
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: ISDN BRI Issue
That is correct statement, your only other option beside the safe harbor of H.323  is a potentially long and fruitless interaction with the TAC.
Please remember to rate useful posts with the scrollbox below.
Re: ISDN BRI Issue
No information is missing, CM is misbehaving. It expects channel information to be in Call Proceeding and not in Setup Acknowledge, however per Q.931 standard, it can be in either message (that incidentally, convey slightly different semantic).
I'm unable to tell you why, and if it is fixable.
I would recommend stay with H.323, more features, more stability, easier to configure and troubleshoot.
Re: ISDN BRI Issue
Thanks for the reply, unfortunately as the Telco Provider I have to carry out User Acceptance Testing for CallManager and this is a fail. As such I either need to find a fix for this or state that CallManager will not work with the Telco Switch we provide as a MGCP  option
Re: ISDN BRI Issue
753
