ISDN BRI Network Side Configuration of "basic-ni" Sending a Blank Alerting Message
I am trying to integrate a CME 8.6 with an ISDN device.  I have a VIC2-2BRI-NT/TE connected to it's "S" interface and the D channels of the two BRIs are up and working correctly.  The CME is emulating a basic-ni switch.  I can make calls to the device without a problem:
Mar 14 2014 14:30:50.605 CT: ISDN BR0/3/0 Q931: TX -> SETUP pd = 8  callref = 0x7D
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Display i = 'Test'
        Signal i = 0x40 - Alerting on - pattern 0
        Calling Party Number i = 0x0080, '12'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0901'
        Locking Shift to Codeset 5
        Codeset 5 IE 0x2A  i = 0x808D09, 'Test'
Mar 14 2014 14:30:50.661 CT: ISDN BR0/3/0 Q931: RX <- ALERTING pd = 8  callref = 0xFD
        Channel ID i = 0x89
                Exclusive, B1
... but when I try to receive a call from it, I get a "Cause i = 0x80E034 - Mandatory information element missing" message.
Mar 14 2014 14:31:02.034 CT: ISDN BR0/3/0 Q931: RX <- SETUP pd = 8  callref = 0x01
                Standard = CCITT
        Channel ID i = 0x83
                Preferred, Any B-channel
        Keypad Facility i = '12'
        Calling Party Number i = 0x80, '0901'
Mar 14 2014 14:31:02.058 CT: ISDN BR0/3/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
Mar 14 2014 14:31:02.074 CT: ISDN BR0/3/0 Q931: TX -> ALERTING pd = 8  callref = 0x81
Mar 14 2014 14:31:02.098 CT: ISDN BR0/3/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
Mar 14 2014 14:31:02.098 CT: ISDN BR0/3/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
If I switch the switch type to basic-net3, the inbound works:
Mar 14 2014 14:56:40.952 CT: ISDN BR0/3/1 Q931: RX <- SETUP pd = 8  callref = 0x01
                Standard = CCITT
        Channel ID i = 0x83
        Calling Party Number i = 0x0081, '0903'
        Called Party Number i = 0x80, '12'
        High Layer Compat i = 0x9181
Mar 14 2014 14:56:40.980 CT: ISDN BR0/3/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
Mar 14 2014 14:56:40.996 CT: ISDN BR0/3/1 Q931: TX -> ALERTING pd = 8  callref = 0x81
        Progress Ind i = 0x8188 - In-band info or appropriate now available
What I notice is that the alerting message when in basic-ni mode is blank and not sending the "Progress Ind i = 0x8188 - In-band info or appropriate now available" message that it is supposed to be.
Would any one know a way to force it to send the 0x8188 message?  ... or is this a Cisco bug?
129
