ISDN BRI Not working with h323 gateway
We are using NM-4B-S/T= as a ISDN BRI card to terminate ISDN BRI lines from service provided to make incoming and outgoing calls on H323 gateway. I am facing a problem of with error as below.
025786: *Apr 23 08:12:12.716: ISDN BR2/2 **ERROR**: accept_incoming_csm_call: modem problem Bearer capability not available(0x3A): b channel 0, call id 0x8B.
I have also added isdn incoming-voice modem command as per the isdn disconnect cause codes. But still the problem persist. We have tested BRI line with BRI Analyzer and calls are landing on it successfully.
Is this NM-4B-S/T= supported to make and receive voice calls.
I have successfully tested calls made from analog lines on the same gateway, Problem is only with the BRI lines.
Kindly suggest,
Nitesh
Gold
Re: ISDN BRI Not working with h323 gateway
Try to add this command to your voice ports:
bearer-cap Speech
Hope this helps,
Juan Luis
Hi Juan,
I am using c3845-spservicesk9-mz.123-11.T11.bin" IOS on my Gatway router. And the command bearer-cap speech is not supported.
Kind Regards,
Nitesh
Hall of Fame Super Gold
No the NM-4B-S/T does NOT support voice calls, data only. Only VIC-2BRI (first letter V as in Voice) will support voice.
Hope this helps, if so please rate post!
This was card issue and it got resolved by replaceing the card with VIC-2BRI.
Thanks for all your help.
Nitesh
229
