ISDN BRI outgoing/incoming call problem
I have the following setup:
Cisco 2621XM with NM-HD-2V and VIC2-2BRI-NT-TE
IOS 12.4(4)T
CallManager Express 3.3
2x ISDN NT connected to PSTN via BRI (in port 0).
I'm trying to achieve the following:
Outgoing calls work if dialed from phones
Incoming calls come in on hunt group (MSN numbers 4959 and 4283).
At present this is what I'm getting:
Outgoing call:
Jul 23 08:22:55.431: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 84 changed to up
Jul 23 08:22:55.439: ISDN BR1/0 Q931: TX -> SETUP pd = 8  callref = 0x0A
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Calling Party Number i = 0x0080, '5512'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '073xxxxxxx'
Jul 23 08:22:55.731: ISDN BR1/0 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8A
Channel ID i = 0x89
Jul 23 08:22:55.735: ISDN BR1/0 **ERROR**: host_information: Unexpected INFO - call id 0x800A
Jul 23 08:22:57.371: ISDN BR1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x8A
Cause i = 0x8AFF - Interworking error; unspecified
Progress Ind i = 0x8288 - In-band info or appropriate now available
Jul 23 08:22:57.375: ISDN  SERROR: calltrkr_call_cleared: no idb, call failed
Jul 23 08:22:57.379: ISDN BR1/0 **ERROR**: host_disconnect: isdn_info NULL on Disconnect call id 0x800A
Jul 23 08:22:57.383: ISDN 540C08928170 Error: Invalid DSL (0)  SERROR: isdn_get_display_text_from_gtd: false ret
Jul 23 08:22:57.387: ISDN BR1/0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x800A
Jul 23 08:22:57.391: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0A
Cause i = 0x80AF - Resource unavailable, unspecified
Jul 23 08:23:00.887: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 84 changed to down
Jul 23 08:23:00.887: ISDN BR1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Incoming call:
Jul 23 08:24:07.760: ISDN BR1/0 Q931: RX <- SETUP pd = 8  callref = 0x11
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0x89
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x0183, '021xxxxxxx'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '4959'
Jul 23 08:24:07.764: ISDN BR1/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 0 tei 127 ces 0 ev 0x3
Jul 23 08:24:07.792: ISDN 7F356C40800B Error: Invalid DSL (0)  SERROR: isdn_get_display_text_from_gtd: false ret
Jul 23 08:24:07.796: ISDN 7F356C40800B Error: Invalid DSL (0)  Error: Invalid DSL (0)  SERROR: isdn_get_display_text_from_gtd: false ret
Jul 23 08:24:07.828: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 84 changed to up
Jul 23 08:24:07.832: ISDN BR1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x91
Channel ID i = 0x89
Jul 23 08:24:07.860: ISDN BR1/0 Q931: TX -> CONNECT pd = 8  callref = 0x91
Channel ID i = 0x89
Jul 23 08:24:08.200: ISDN BR1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x11
Jul 23 08:24:08.208: %ISDN-6-CONNECT: Interface BRI1/0:1 is now connected to 0218554283 N/A
Jul 23 08:24:11.296: ISDN BR1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x11
Cause i = 0x8090 - Normal call clearing
Jul 23 08:24:11.304: %ISDN-6-DISCONNECT: Interface BRI1/0:1  disconnected from 0218554283 , call lasted 3 seconds
Jul 23 08:24:11.316: ISDN BR1/0 Q931: TX -> RELEASE pd = 8  callref = 0x91
Jul 23 08:24:11.460: ISDN BR1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x11
Jul 23 08:24:13.460: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 84 changed to down
Jul 23 08:24:13.464: ISDN BR1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
This is my current configuration:
Current configuration : 3475 bytes
! Last configuration change at 10:49:28 SAST Fri Jul 23 2010
! NVRAM config last updated at 10:34:13 SAST Fri Jul 23 2010
version 12.4
service password-encryption
hostname voice
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxx
no aaa new-model
resource policy
clock timezone SAST 2
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
ip cef
isdn switch-type basic-net3
voice-card 1
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  header-passing
  subscription maximum accept 5
  registrar server expires max 600 min 60
voice register global
mode cme
source-address 10.1.1.123 port 5060
authenticate all
timezone 29
voice register dn  9
number 5509
no-reg
voice register dn  10
number 5510
no-reg
voice register dn  11
number 5511
no-reg
voice register dn  12
number 5512
no-reg
voice register dn  13
number 5513
no-reg
voice register dn  60
number 5560
voice register dn  61
number 5561
voice register pool  1
id mac 000B.8218.6210
number 1 dn 9
max registrations 24
username 5509 password 5509
codec g711alaw
voice register pool  2
id mac 000B.8219.4241
number 1 dn 10
username 5510 password 5510
codec g711alaw
voice register pool  3
id mac 000B.8218.9D96
number 1 dn 12
username 5512 password 5512
codec g711alaw
voice hunt-group 1 longest-idle
final 5500
list 5512,5510,5511,5509,5513
timeout 180
hops 5
pilot 4959
voice hunt-group 2 longest-idle
final 5500
timeout 180
hops 5
pilot 4283
username admin privilege 15 secret 5 xxxxxxxxxx
ip address 10.1.1.123 255.255.255.0
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
interface BRI1/1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.2
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
control-plane
voice-port 1/0/0
voice-port 1/0/1
dial-peer voice 1 pots
destination-pattern 0T
incoming called-number .T
port 1/0/0
forward-digits all
dial-peer voice 2 pots
port 1/0/0
forward-digits all
port 1/0/1
forward-digits all
dial-peer voice 3 voip
destination-pattern 5500
session protocol sipv2
session target ipv4:10.1.1.158
session transport tcp
dtmf-relay rtp-nte
telephony-service
max-ephones 24
max-dn 72
ip source-address 10.1.1.123 port 2000
create cnf-files version-stamp Jan 01 2002 00:00:00
voicemail 5500
max-conferences 4 gain -6
moh music-on-hold.au
transfer-system full-consult
transfer-pattern 5...
line con 0
line aux 0
line vty 0 4
password 7 xxxxxxxxxxxx
login
transport input all
ntp clock-period 17180178
ntp server 196.25.1.1
end
Would someone please be so kind as to assist me with this problem?
Kind regards,
Lionel
Re: ISDN BRI outgoing/incoming call problem
Just to add - internals calls are working fine.
Hi Guys,
Just want to check if you ressolved the issue? because i am having same issue.
3159
