Community Member
ISDN BRI TEI assignment - drops out
Have a 2821 running 12.4(9)T Software (C2800NM-SPSERVICESK9-M), Version 12.4(9)T, with four BRI interfaces. Gateway is registered with CCM 4.X and local extensions work fine. Occasionally, the interfaces fail and the TEI sits in a wait state.
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 4 CCBs = 0
The Free Channel Mask: 0x80000003
If i cfg the interface and force the connection with "isdn static tei-0" then all is fine - for a while. Then inexplicably this cfg drops out of the interface and inbound calls from the pstn fail. on-net calls are fine.
Any thoughts on how to nail a more persisitant solution very welcome. tks
1 REPLY
Hall of Fame Super Gold
Re: ISDN BRI TEI assignment - drops out
Hi, please upgrade to 12.4(11)XJ1 and you will be ok with the static tei BRI.
273
