Community Member
ISDN BRI to SIP Configuration on CISCO 2800 Gateway
I want to transfer all the incoming calls on the interface BRI0/0/0 to SIP server, i can make outgoing calls but incoming is not working. rest all interfaces are configured with CCM and are working fine.
Thanks in Advance
Building configuration...
Current configuration : 5007 bytes
version 12.4
service password-encryption
hostname ProcessVG
boot-start-marker
boot system flash c2801-spservicesk9-mz.124-11.T.bin
boot-end-marker
card type e1 0 1
no logging buffered
no logging console
enable secret 5 $1$TI5I$5v0fY73QNvWma33jM0lCI1
no aaa new-model
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 3
network-clock-select 1 E1 0/1/0
ip cef
ip domain name process
ip host CCMPROCESS 192.168.0.204
isdn switch-type primary-net5
trunk group  ANLG
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
signaling forward unconditional
sip
  bind media source-interface FastEthernet0/0
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
ip address 192.168.0.222 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.0.222
interface FastEthernet0/1
ip address 172.16.10.13 255.255.0.0
duplex auto
speed auto
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/0/1
no ip address
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no cdp enable
interface BRI0/3/0
no ip address
isdn static-tei 0
interface BRI0/3/1
no ip address
isdn static-tei 0
ip route 0.0.0.0 0.0.0.0 192.168.0.221
ip route 69.60.6.160 255.255.255.224 192.168.0.157
ip http server
no ip http secure-server
logging 192.168.0.253
control-plane
disable-eadi
voice-port 0/0/0
compand-type a-law
voice-port 0/0/1
compand-type a-law
voice-port 0/1/0:15
voice-port 0/2/0
trunk-group ANLG
connection plar 6000
caller-id enable
voice-port 0/2/1
caller-id enable
voice-port 0/2/2
connection plar 6100
caller-id enable
voice-port 0/2/3
caller-id enable
voice-port 0/3/0
compand-type a-law
voice-port 0/3/1
compand-type a-law
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.0.204
ccm-manager config
mgcp
mgcp call-agent 192.168.0.204 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 192.168.0.204 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register Xcodex
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 5 pots
service mgcp
direct-inward-dial
port 0/1/0:15
dial-peer voice 10 voip
destination-pattern 56.
session target ipv4:192.168.0.204
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1000 voip
numbering-type unknown
destination-pattern .T
session protocol sipv2
session target ipv4:192.168.0.100:5060
session transport udp
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 11 pots
destination-pattern 9T
incoming called-number .T
port 0/0/0
dial-peer voice 12 pots
trunkgroup ANLG
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry options 0
timers trying 1000
sip-server ipv4:192.168.0.100
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.0.222 port 2000
max-ephones 30
max-dn 40
transfer-pattern ...
call-forward pattern ...
line con 0
password 7 083B45430B100B4342
login
line aux 0
password 7 10540014071E1C5F5C
login
line vty 0 4
login
scheduler allocate 20000 1000
end
1 REPLY
Hall of Fame Super Gold
You can take "debug isdn q931" and "debug ccsip message" with "term mon" to see what's wrong.
2115
