Silver
ISDN BRI & VoIP/IPT at Home
I have UK ISDN BRI circuit coming into my home. I would like to connect a gateway upto this and run CME. Hopefully I can then begin to build ontop of this like adding CUE.
I have the following qtns:
1) What is the minimum router (Gateway) platform to be provisioned?
2) What modules do I require?
3) Which version of code is needed?
4) Since I will be replacing anologue cordless phone, will the Cisco Wireless IP phone be any good and are there any additions required?
thanks in advance
Ajaz Nawaz
1 REPLY
Hall of Fame Super Gold
Re: ISDN BRI & VoIP/IPT at Home
CUE-AIM can be hosted on the 2801 ISR. Actually you could use even smaller router live 1721-V, 1751-V, but these don't support CUE and are going end of sales soon if not already. So these are better for buying used gear.
you need a voice bundle, a BRI card and nothing else basically nothing talk to your reseller and if unsure come back here with the proposed list.
Try to get also a smartnet contract so you can register for CCO download and upgrade code as you whish.
The Cisco wireless phones are good if you like them, else a traditional one, better if with ISDN will work as weel. Watch out the the linksys phones aren't supported by CME right now but they will eventually.
132
