Community Member
ISDN BRI won't rollover
I have a 2851 with 2 VIC2-2BRI-NT/TE. I configured trunk groups to rollover between the 4 voice ports for outbound calls. Everything works fine with all the ports connected (I can place and receive many calls at the same time). Then I disconnected all of the ports except the BRI0/0/1 and when I try to place a call, I get a fast busy. The router seems always to try the first port (BRI0/0/0) as that log says (and there's nothing connected in that port):
Dec 5 22:20:26.627: %LINK-3-UPDOWN: Interface BRI0/0/0, changed state to up
Dec 5 22:20:34.631: %LINK-3-UPDOWN: Interface BRI0/0/0, changed state to down
Here's the config:
trunk group BRI
hunt-scheme sequential both up
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn twait-disable
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group BRI
interface BRI0/0/1
no ip address
isdn twait-disable
isdn static-tei 0
trunk-group BRI
interface BRI0/1/0
no ip address
isdn twait-disable
isdn static-tei 0
trunk-group BRI
interface BRI0/1/1
no ip address
isdn twait-disable
isdn static-tei 0
trunk-group BRI
dial-peer voice 800 pots
trunkgroup BRI
destination-pattern 0T
Thanks!!
Re: ISDN BRI won't rollover
As you are using the sequential hunt-scheme have you tried using preferences? By default Sequential trunk-group will use the interface with the highest preference is selected.
Try assigning or configuring your interfaces starting BRI0/1/1 with 'trunk-group BRI 1' and then BRI0/1/0 with 'trunk-group BRI 2' and so. This should then force BRI0/1/1 interface to be selected first.
Hope this helps.
Allan.
Community Member
Thanks for your reply. I tried what you suggest and the BRI0/1/1 could be selected first. But what I'm looking for, is to have a rollover in case of failure. That's the reason why I do this test. I tried other hunt schemes but when a port that is not connected is selected first, the router won't go to the next one... Any ideas??
Hall of Fame Super Gold
under "trunk group XXX", please try "max-retry 2".
Community Member
Thanks for your reply. No it doesn't work either. And now the router starts with the Bri0/1/0... Do you think this is a bug? Thanks again!
actually I think that failure to try another line in a trunk group made of BRIs, is a definite bug. I have the same issue in my installations, and the workaround is to remove the BRI from the trunk-group.
However, I didn't tried the "max-retry" config with "hunt-scheme round-robin". Have you ?
Community Member
Hi, yes I have tried all hunt schemes... Same result. Your workaround seems to be the only thing to do since the router have the same behavior if I shutdown the BRI ports that are not connected.
Thanks for your help!!
You are welcome. Unfortunately it can take a lot of time and effort to convince Cisco that it is a bug, so I didn't pursued the issue any further.
Who has the will to do that and is successful, that would be an accomplishment benefiting everyone.
add the following to you config:
trunk group BRI
max-retry 3 ! you have 4 ports
voice-class cause-code 1
voice class cause 1
no-circuit
no-channel
temp
If this does not work, do a "debug voice ccapi inout" and you'll see somewhere (tons of text) the cause code.
In the voice-class cause you can use the "?/help" and look if you find the matching code.
Worked for me, but is not really good documented... :-)
Good luck,
Martin
Good info, will try as I got a chance.
Just another point to be aware of:
If you have outgoing translations on the ports or the trunk, they will go wrong.
The translation will be done even if call cannot be placed and the next port/trunk translation will be done again.
Example:
--DialPeer---Trunk---Port (out of order)
---Port (ok)
translation on peer: ok
translation on trunk/port: will translate twice :-)
-> If you want to use trunk, use outgoing translations in dial-peer only if you need redundancy.
This is sad, but this is IOS...
I got a case open on that - but this seems to be a case of "works as designed".
/Martin
Hi Martin,
good info again, thanks. Typical case of cisco short sighting in design and testing.
Next thing you will discover, is that what was not a bug when you reported it, it becomes one when reported by a large and important customer with an order at stake, or if it is mentioned in an highly visible venue, like ietf meeting, etc.
Community Member
try without the hunt function.
nterface BRI0/0/0
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI0/0/1
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn twait-disable
isdn static-tei 0
Greets,
Norbert
Community Member
Great one - worked like a charm.. Gave you a "high five" for that one..
Thanks a lot!
Cheers
/David
Coming into the thread a little late ... but perhaps you would all like to know what is happening here.
If you unplug the BRI ports and run 'debug voip ccapi inout', the clearing code will actually be 1 - unallocated/unassigned number.
This happens because the voice port status is reflected on the actual dial peer. If you do a 'sh dial peer voice status', you will see the POTS dial peers are in the down state.
If a call comes into the router from the VOIP leg, the dial peers that are in the down state will be ignored , so no match will be made on the destination pattern of the first dial peer that the router hunts through and as a result, IOS sends a clear code of unallocated /unassigned number. At the VOIP processing layer, a decision is made that there is no point retrying the call since the number does not exist. So IOS clears the call down and nothing more happens.
There is a simple fix ... Add the command 'no dial-peer outbound status-check pots' . This command tells the software to ignore the physical status of the voice port. The voice call on this dial peer still fails, but it will return cause value 34 - no circuit/channel available. When this gets passed back to the voice processing software , it then retries the call and will hunt through the all the dial peers.
The funny thing is that this changed somewhere in IOS releases.
Early releases sent a "no circuit available", later releases send a "number unassigned".
The command 'no dial-peer outbound status-check pots' is extremely important if there are redundant gateways.
In one of my projects with CCM I upgraded the IOS, did a redundany test (which worked fine with the old release) and saw that the (new) default behavior destroyed redundancy - the CCM saw no point in trying the other gateway if the number is unassigned anyway (you can change this behaviour in a service parameter - bur there are unfunny side effects)
Since then I always configure that.
On CCO you find this command only in the command reference - I did not find it once in a config example.
Here some details from another thread:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddd088b/0#selected_message
/Martin
Community Member
Interesting explanations, thanks!
Thing is that with my CME - 12.4(4)XC4 - POTS dial peers don't go down after unplugging one BRI. I don't need "no dial-peer outbound status-check pots" to get that behaviour with my DDI/point-to-point Setup.
Either way, hunting does not continue and I was forced to apply mstreule's workaround.
Cheers
/David
Hi Paul, the thing is that we're talking about trunk-group so the DP is not actually associated to any individual port.
There's no rehunting at DP level in this case, so need for workaround mentioned.
492
