ISDN CALL ARE BARRED error on PRI
I have connected configured a PRI trunk from cisco to nortel option 11c.
Call manager config has been done and gateway has been config as MGCP , but during making outbound calls i am getting the " ISDN CALLS ARE BARRED ERROR message.
Any help will be appreciated...
BBSgateway#sh isdn sta
Global ISDN Switchtype = primary-dms100
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/1/0:23 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = primary-dms100
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 17
Total Allocated ISDN CCBs = 0
BBSgateway#
000481: *Nov 16 22:36:54.646: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0007
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0181, '1003'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '9197737000'
Plan:ISDN, Type:National
000482: *Nov 16 22:36:54.666: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x87
Cause i = 0x81B6 - Incoming calls are barred
1 REPLY
Silver
Re: ISDN CALL ARE BARRED error on PRI
I had the exact same outputs and symptoms but with Telco who gave me wrong information about the PRI switch type. Try changing the PRI switch type and see if the problem goes away.
In our case we had to change the switch type from primary-ni2 to primary-5ess.
827
