ISDN Calls - Bearer capability not implemented
Hi.
Many of the calls are established but only some of them are disconnected.
I have this log in the Cisco 2900
Jan 20 13:26:52.615: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0166
        Cause i = 0x8090 - Normal call clearing
Jan 20 13:26:52.647: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8166
Jan 20 13:26:52.647: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0166
Jan 20 13:26:57.026: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 528181530100
Jan 20 13:26:57.026: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0167 callID = 0x80E8 switch = primary-qsig interface = User
Jan 20 13:26:57.026: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0167
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0080, '528181530100'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '233000'
Jan 20 13:26:57.046: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8167
Jan 20 13:26:57.050: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8167
Jan 20 13:26:57.058: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8167
        Facility i = 0x9FAA068001008201008B0100A118020287DE020102800F44465F4154435F434F4E545F505041
        Progress Ind i = 0x8182 - Destination address is non-ISDN
Jan 20 13:26:57.058: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0167
Jan 20 13:26:57.262: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0167 Cause i = 0x80C1 - Bearer capability not implemented
Jan 20 13:26:57.290: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8167
Jan 20 13:26:57.294: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0167
Do you have any aidea ?
Thanks..
Everyone's tags (3)
Hall of Fame Super Silver
Apply the following to your D-channel:
voice-port 0/0/0:23
bearer-cap Speech
Chris
Hi Cris, thanks for your feedback.
I tried with this command but the problem continue.
Regards.
I've seen this caused by codec mismatch as well, could that be the issue here?
Chris
Hi Chirs.
We´ve tried change the codecs but we don´t have results.
Do you know a debug command in order to detect the codec mismatch ?
Thanks.
To detect codec mismatch you would need to look at the voip protocol debugs, depending on protocol user it would be different commands, for SIP use "debug ccsip messages"
H323 - "debug h225" or "debug h245 asn1"
MGCP you would look at CCM SDI traces.
HTH,
Chris
Got to the bottom of this
For MGCP Gateways anyway ..
On Call Manager - goto the gateway in question and drill into the Cisco MGCP T1 port config..
Scroll down and change the Channel IE Type from the default ..
USE Number when 1B OR Slotmap
TO the correct setting
Timeslot Number
PCM Type = u-law
thats for US T1 PRI
Hope that helps ..
7806
