05-30-2008 01:52 AM - edited 03-15-2019 10:58 AM
Hi all,
Can anyone please confirm that the following card can be used for a ISDN PRI for voice connection: VIC2-2BRI-NT/TE
Solved! Go to Solution.
05-30-2008 02:45 AM
Ni, it cannot be used for PRI. You need VWIC or VWIC2, and a number of DSP resurce depending on how many channels you have active.
05-30-2008 02:45 AM
05-30-2008 06:32 AM
I had a similar issue and you may need to upgrade the IOS on the router. I had this issue before and as it turned out, the VIC2 card was a second generation card and the router's IOS did not support 2nd generation cards. YOu may want to look that up.
05-30-2008 08:33 AM
Sorry but what did you mean by you may need to upgrade the IOS on the router?
so to sum what you said i can use it for PRI in the event if i upgrade the IOS but the card has the Name BRI so it's only usable for BRI connection not PRI thanks for replying soon i need this kind of information :)
