ISDN card issue
Hi all,
Can anyone please confirm that the following card can be used for a ISDN PRI for voice connection: VIC2-2BRI-NT/TE
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: ISDN card issue
Ni, it cannot be used for PRI. You need VWIC or VWIC2, and a number of DSP resurce depending on how many channels you have active.
Re: ISDN card issue
Re: ISDN card issue
I had a similar issue and you may need to upgrade the IOS on the router. I had this issue before and as it turned out, the VIC2 card was a second generation card and the router's IOS did not support 2nd generation cards. YOu may want to look that up.
Re: ISDN card issue
Sorry but what did you mean by you may need to upgrade the IOS on the router?
so to sum what you said i can use it for PRI in the event if i upgrade the IOS but the card has the Name BRI so it's only usable for BRI connection not PRI thanks for replying soon i need this kind of information :)
102
