ISDN cause code 80bf
The calls are getting disconnected at Voice gateway. Q931 debug logs says cause code 80bfservice option not available. Please let me know wheher it is an issue with Service provider or I need to modify my VG configuration.
Krishna Mohan
Hall of Fame Super Gold
Re: ISDN cause code 80bf
Need to see full trace to say.
Please find the trace logs
Trace should be very short, put it here without using attachments.
Pls find
Bearer Capability i = 0x8090A3
  Standard = CCITT
  Transfer Capability = Speech
  Transfer Mode = Circuit
  Transfer Rate = 64 kbit/s
Channel ID i = 0xA98385
  Exclusive, Channel 5
Calling Party Number i = 0x2181, '9990860046'
  Plan:ISDN, Type:National
High Layer Compat i = 0x9181
*Sep  4 14:35:47.625: ISDN Se0/1/1:15 Q921: User TX -> RR sapi=0 tei=0 nr=42
*Sep  4 14:35:47.625: ISDN Se0/1/1:15 Q931: Received SETUP  callref = 0xACEF callID = 0x7BF8 switch = primary-net5 interface = User
*Sep  4 14:35:47.625: ISDN Se0/1/1:15 Q921: User TX -> INFO sapi=0 tei=0, ns=32 nr=42
*Sep  4 14:35:47.625: ISDN Se0/1/1:15 Q931: CALL_PROC pd = 8  callref = 0xACEF
*Sep  4 14:35:47.629: ISDN Se0/1/1:15 Q921: User TX -> INFO sapi=0 tei=0, ns=33 nr=42
*Sep  4 14:35:47.629: ISDN Se0/1/1:15 Q931: DISCONNECT pd = 8  callref = 0xACEF
Cause i = 0x80BF - Service/option not available, unspecified
*Sep  4 14:35:47.633: ISDN Se0/1/1:15 Q921: User RX <- RR sapi=0 tei=0 nr=33
*Sep  4 14:35:47.637: ISDN Se0/1/1:15 Q921: User RX <- RR sapi=0 tei=0 nr=34
*Sep  4 14:35:47.709: ISDN Se0/1/1:15 Q921: User RX <- INFO sapi=0 tei=0, ns=42 nr=34
*Sep  4 14:35:47.709: ISDN Se0/1/1:15 Q931: RELEASE pd = 8  callref = 0x2CEF
*Sep  4 14:35:47.709: ISDN Se0/1/1:15 Q921: User TX -> RR sapi=0 tei=0 nr=43
*Sep  4 14:35:47.709: ISDN Se0/1/1:15 Q921: User TX -> INFO sapi=0 tei=0, ns=34 nr=43
*Sep  4 14:35:47.709: ISDN Se0/1/1:15 Q931: RELEASE_COMP pd = 8  callref = 0xACEF
*Sep  4 14:35:47.713: ISDN Se0/1/1:15 Q921: User RX <- RR sapi=0 tei=0 nr=35
*Sep  4 14:35:48.541: ISDN Se0/0/1:15 Q921: User TX -> RRp sapi=0 tei=0 nr=1
Seem to be a problem in your router, are you the technician ?
Yes, I have configured this router. Please let me know the issue.
Sorry,
You expect people to be able tell what is wrong, without knowing nothing about what you are trying to do, and how ?
Dude, I have clearly mentioned the calls are getting diconnected in the VG with a cause code of 80bf. I have uploaded the debug logs as you asked. Then what else you need?
Can you upload the configs for the gateway?
Does outbound work ok?
What does the call flow look like?  For example:  Call manager==h323==Gateway==PRI==Telco.
K
This is a CVP SIP Comprehensive model. PSTN-Gateway-CVP-ICM.
Pls find the VG configs as well.
Thanks/Regards
I suspect you might not be matching up to a dial peer.
Can I see a call using the following debugs?
debug isdn q931
debug voip ccapi inout
debug ccsip mess
You might get the PRI debugger program and see what it says.
Thanks. The issue is not with the PRI. CVP call server licenses were not uploaded properly and it had only 2 default licenses.
"Dude" ? °Then what else" ?
I don't think that is the right attitude for a supposed network professional that comes to get free support.
Regards, Paolo.
1024
