11-06-2008 09:11 PM - edited 03-15-2019 02:24 PM
I am using as5350xm (connected to a single PRI T1)and asterisk.
Could i specify a specific channel id to dial out?
If not, what mechanism (robin-robin, most idle) does cisco allocate channels for outbound call?
pls kindly advise.
11-06-2008 09:12 PM
I am using SIP to connect as5350xm.
11-07-2008 06:43 AM
Cisco uses descending order by default [Most Telcos default to ascending].
You can change the behavior with:
isdn bchan-number-order {ascending | descending}
-steve
