ISDN 'Channel IE type'
Can anyone elaborate (or share a doc) on exactly what this does? It is a Call Manager configuration option for Digital Access PRI gateways. The available options are ;
*Timeslot number
*Slotmap
*Use number when 1B
*Continous number.
Re: ISDN 'Channel IE type'
When the Channel IE type is set as "timeslot" , this specifies the B channel to use for a call as a number. For example, if a Q931 message such as a Restart message refers to B channel 5, the channel IE contains the number 5.
If it is set as "Use number when 1B" , it will specify the B channel to use as a timeslot (discrete number) for any message that refers to a single B channel, but it will summarise all the timeslots as a bit mask to represent all the channels if the mesage refers to multiple B channels.
This bit mask summary is also refered to as a "Slotmap".
Only certain messages (such as Restart) can specify a range of B channels. Normal call control (Setup/disconnect) generally only references a single B channel. In most cases you don't need to alter this setting.
Refer here for more details (from the CCM help page) -
Timeslot Number - B-channel usage always indicates actual timeslot map format (such as 1-15 and 17-31 for E1).
Slotmap - B-channel usage always indicates a slot map format.
Use Number When 1B - Channel usage indicates a channel map for one B-channel but indicates a slot map if more than one B-channel exists.
Continuous Number - Configures a continuous range of slot numbers (1-30) as the E1 logical channel number instead of the noncontinuous actual timeslot number (1-15 and 17-31).
Thanks.
1591
