ISDN Configuration issue
We are having an issue with a voice over ip architecture where basically we have one pbx on one end connected to a 3825 through a qsig E1 and same thing on the other end. Both routers are connected through the LAN since this is a lab environment before putting it into production.
The call goes through from one end but not from the other. It does go through if we initiate the call from the router instead of the PBX on the not working side.
While troubleshooting, we found the isdn error "invalid call reference value" and the L3 BadPeerMsg.
Apart from this, the configuration is straight forward with session targets and the call does get routed to the pbxs.
Please if you have seen this kind of error before, let us know how you dealt with it.
Regards.
Hall of Fame Super Gold
Re: ISDN Configuration issue
can you collect output of "debug isdn q931"for the failed and successful call (initiated by the router) ?
The "invalid call reference" error may be due to some IOS bug, suggest you upgrade to latest maintenance release of the chosen IOS train.
Silver
There are quite some ugly bugs regarding ISDN signalling and QSIG trunks, I would first upgrade to the latest release before testing any.
HTH,
Leo
I have upgraded to the latest IOS with no success. Here are the two debugs. First the working one:
routeur 3825 cote maquette
sens reussi
le numero 5715 du site maquette appelle vers le site centrale 1851
g isdn q931
debug isdn q931 is ON.
BeniMellal#
ISDN Se1/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839F
Preferred, Channel 31
Facility i = 0x91AA068001008201008B0100A10B02010306042B0C09008400
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0183, '5715'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '1851'
Locking Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x81
ISDN Se1/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8001
Channel ID i = 0xA9839F
Exclusive, Channel 31
ISDN Se1/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8001
Facility i = 0x91AA068001008201008B0100A1150202295006082B0C02885302010603050001000000
Facility i = 0x91AA068001008201008B0100A10C0202296006042B0C09018400
Facility i = 0x91AA068001018201018B0100A1130202297006082B0C0288530201023003800164
Facility i = 0x91AA068001008201018B0100A1410202298006082B0C0288530201003031810C0C06118031383531740200C08221031902000400000000600000000400C00E38008104800500008F806301C37C01C3
Progress Ind i = 0x8088 - In-band info or appropriate now available
ISDN Se1/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0001
Cause i = 0x8090 - Normal call clearing
ISDN Se1/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8001
ISDN Se1/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0001
And here is the Debug of the call Not working:
ISDN Se1/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 1851
ISDN Se1/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 5715
ISDN Se1/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0080 (re-assembled)
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x91AA068001008201008B0100A11502022E9006082B0C02885302010603050001000000
Facility i = 0x91AA068001018201018B0100A15202022EA006082B0C0288530201073042A240303E810100820101A310A0098004313835310A01003003800164A40A8003323530300380010AA50B8004313835313003800164A60B8004353731353003800139
Facility i = 0x91AA068001008201008B0100A11502022EB006082B0C02885302014C30058003323530
Facility i = 0x91AA068001018201018B0100A12C02022EC006082B0C028853020104301C80033235300202141F800332353002021420A00380010AA10380010A
Facility i = 0x91AA068001008201008B0102A11402022ED002013B300B30090A01050A01030A0104
Facility i = 0x91AA068001008201008B0100A10C02022EE006042B0C09008400
Facility i = 0x91AA068001018201018B0100A11302022EF006082B0C0288530201013003800164
Facility i = 0x91AA068001018201018B0100A11302022F0006082B0C0288530201113003800139
Facility i = 0x91AA068001008201018B0100A13402022F1006082B0C02885302010030248222031C0200040D000000200000000400C00E3800810480E500000F040088804F021F00
Calling Party Number i = 0x80, '1851'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '5715'
High Layer Compat i = 0x9181
ISDN Se1/0/0:15 Q931: TX -> SEGMENT pd = 8 callref = 0x0080
Segmented Message i = 0x8105
1st segment. Segments remaining : 1
Segmented Message i = 0x0005
Segments remaining : 0
ISDN Se1/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8080
Cause i = 0x85D1 - Invalid call reference value
ISDN Se1/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0081 (re-assembled)
Standard = CCITT
ISDN Se1/0/0:15 Q931: TX -> SEGMENT pd = 8 callref = 0x0081
ISDN Se1/0/0:15 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0x80 callid 0x0
ISDN Se1/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8081
ISDN Se1/0/0:15 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0x81 callid 0x0
BeniMellal#
Gold
can u attach show run from the router where the 2nd debug was collected from ?? One possible reason is the "segment" msg being sent by the Router and the other end is unable to interpret it. Also, ensure that the isdn switch-type is set is the same configured on both ends
Here is the show run with IP hidden.
Thanks.
Building configuration...
Current configuration : 2413 bytes
version 12.4
hostname BeniMellal
boot-start-marker
boot system flash:c3825-entservicesk9-mz.124-13a.bin
boot system flash:c3825-entservicesk9-mz.124-13b.bin
boot-end-marker
no logging on
enable secret 5
no aaa new-model
network-clock-participate slot 1
voice-card 0
dspfarm
voice-card 1
dspfarm
ip cef
no ip domain lookup
isdn switch-type primary-qsig
voice iec syslog
controller E1 1/0/0
pri-group timeslots 1-31
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
duplex auto
speed auto
media-type rj45
interface Serial1/0/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
no isdn T309-enable
no cdp enable
interface Serial2/0
encapsulation ppp
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip http server
no ip http secure-server
control-plane
voice-port 1/0/0:15
dial-peer voice 57 pots
destination-pattern 57..
direct-inward-dial
port 1/0/0:15
forward-digits all
dial-peer voice 1000 voip
destination-pattern 1...
session target ipv4:x.x.x.x
ip qos dscp cs5 media
dial-peer voice 56 pots
destination-pattern 56
direct-inward-dial
port 1/0/0:15
forward-digits all
dial-peer voice 4000 voip
destination-pattern 4...
dial-peer voice 23 pots
destination-pattern 2300
direct-inward-dial
port 1/0/0:15
forward-digits all
dial-peer voice 7000 voip
destination-pattern 7...
dial-peer voice 5715 pots
destination-pattern 5715
direct-inward-dial
port 1/0/0:15
forward-digits all
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 0 0
password
login
scheduler allocate 20000 1000
end
Gold
looks like the issue is with the Facility IE message. Looks like we are sending a lot of information, which is not supported on the other end. Can you check the PBX configuration to see what all is the PBX typing to send within the Facility IE messages ?
Unfortunately, we do not have access to any traces on the pbx side (Siemens Hicom 150). So, I cannot get the info you are asking for.
Regards.
What IOS are you running now ? Can you send the configuration ?
Apparentely the problem is due to segmentation. Either the cisco does not segment correctly, or the PBX does not understand how the cisco does that. You need to get some support from the PBX people in order to see whay so many facilities are being passed.
Can you please explain the purpose of facilities .
Thanks.
Hard to tell, one would need to decode them. For sure it is a lot of them. I think you have two choice:
1. find a way to not pass that many facilities, perhaps if you was to use SIP, it would not pass that many facilities Also, there is aparamente "qsig decode" under voice service, that you can try tpo see if it changes something.
2. use transparent tccs to trunk the two pbx's. Look for TCCS on CCO, there are configuration guides. In this way, the signaling is passed unchanged, and the voice channels are trunked permanently with a compression of your choice, and VAD optionally.
Did you resolve this issue ?
I am having similar problems where the router is sending segmented ISDN messages to the PBX, which fails the call.
Phil
An upgrade of the IOS plus the following command fixed the problem:
voice service voip
qsig decode
isdn incoming-voice modem
Regards.
956
