Silver
ISDN disconnect
I have a callmanager 4.1 and a 1760 with some BRI's under MGCP control. Someone cannot call us. After some debugging I have seen the following:
Good call:
ISDN BR0/0 Q931: RX <- SETUP pd = 8 callref = 0x1F
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x0183, '210xxxxxxx'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xC1, '64xxxxx'
Plan:ISDN, Type:Subscriber(local)
ISDN BR0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x9F
Channel ID i = 0x8A
Channel ID i = 0x8A
ISDN BR0/0 Q931: TX -> ALERTING pd = 8 callref = 0x9F
Progress Ind i = 0x8088 - In-band info or appropriate now available
ISDN BR0/0 Q931: TX -> CONNECT pd = 8 callref = 0x9F
ISDN BR0/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x1F
ISDN BR0/0 Q931: RX <- RELEASE pd = 8 callref = 0x1F
Cause i = 0x829A - Non-selected user clearing
ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x1F
Cause i = 0x8290 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
ISDN BR0/0 Q931: TX -> RELEASE pd = 8 callref = 0x9F
Wrong call:
ISDN BR1/1 Q931: RX <- SETUP pd = 8 callref = 0x27
Sending Complete
Standard = CCITT
Channel ID i = 0x8A
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '210xxxxxxx'
Low Layer Compat i = 0x8090A3
ISDN BR1/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA7
Cause i = 0x80E4 - Invalid information element contents
The difference between these calls is the message: Low Layer Compat i = 0x8090A3
Any idea why I receive this and is there a way to ignore this?
JH
Bronze
Re: ISDN disconnect
Could you please include more information about the problem?
Is this happening only for incoming calls from the PSTN? What do you hear when you make the call that is not completed?
Are you able to replicate the problem at will?
Is the problem random or does it happen always for the same calling party?
Silver
Re: ISDN disconnect
Hello Jorge,
It is simple:
It only happens on inbound calls and only from this customer and always.
The customer that calls us hears a busy tone.
Looks to me that they are sending something wrong to me, but they claim they have no problems calling anyone else, except us.
Jan
Hall of Fame Super Gold
Re: ISDN disconnect
Is not that they are sending anything worng, it that the CM doesn't like the LLC IE as you noted. It is a perfectly legal IE by the way, sometime present when the call comes from a cellphone or via a transit network.
The IE cannot be filtered. Either upgrade or fix the CM to accept it (I sorry, I don't really know how), or configure the GW for H.323 and it would have no problem in receiving the LLC IE.
245
