ISDN error message
Hi Guys,
I am experiencing an issue with incoming calls on certain numbers within a range of ddi`s. The debug isdn q931 is returning the following:
Jul 6 11:39:59.743 UTC: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0050
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA193040000
Preferred, Channel 4
Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0083, '4421836482930'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '1234567'
Jul 6 11:39:59.763 UTC: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8050
Channel ID i = 0xA993040000
Exclusive, Channel 4
TK-VCE-RT01#
Jul 6 11:39:59.983 UTC: ISDN Se0/0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 9, call id 0x1BED, call ref 0x8050, event 0x89
Jul 6 11:39:59.983 UTC: ISDN **ERROR**: Module-l3_sdl_u Function-Ux_BadMsg Error-Source ID = 400 Event = 89
TK-VCE-RT01#
Jul 6 11:40:09.856 UTC: ISDN Se0/0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 9, call id 0x1BED, call ref 0x8050, event 0x89
Jul 6 11:40:09.856 UTC: ISDN **ERROR**: Module-l3_sdl_u Function-Ux_BadMsg Error-Source ID = 400 Event = 89
Jul 6 11:40:09.992 UTC: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0050
Cause i = 0x82E6333130 - Recovery on timer expiry
Jul 6 11:40:09.996 UTC: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8050
Jul 6 11:40:10.044 UTC: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0050
I have tried adjusting the ISDN timer but this has not made any difference. Does anyone know why this would affect only certain numbers in a range and what can be done to fix this, thanks.
Hall of Fame Super Gold
Re: ISDN error message
Exact IOS used ?
c2800nm-spservicesk9-mz.124-20.T.bin
Can you use a mainline like 12.4(3j) - much less buggier.
Also check what is going on with these DIDs what the final destination is doing.
Hi Bevil,
Unless i can definately prove it is an IOS issue it would be a bit difficult to change the IOS.
When the call comes in i have a translation rule which is translating this number into 0201010 which is a mobile voice access number.
I then have a pots dial peer and a voip dial peer to match this newly translated number but it is not even hitting my pots dial peer, config is as follows :
dial-peer voice 0201010 pots
description Mobile Voice Access
service ccm
incoming called-number 0201010
no digit-strip
dial-peer voice 124 voip
description Mobile Voice Access Calls
preference 1
destination-pattern 0201010
progress_ind setup enable 3
session target ipv4:10.10.10.10
dtmf-relay h245-alphanumeric
no vad
When dialling this number in particular i get a message from the carrier something about the call not being completed its in Tokyo.
If i ring another number in the same range it goes through perfectly fine.
I don't have to prove anything, the abnormality is evident.
Either "service ccm" does something wrong, or router becomes confused so telco disconnects.
Sorry i think you misunderstood what i was saying. I am not asking you to prove something i just mean my client would want me to be sure it is the IOS before letting me change it. I do agree with you tho so sorry if it sounded wrong.
I will try remove the config altogether and start again in case something has been missed.
Thanks for taking a look i appreciate it.
This message resolved my problem!!
I've been trying to resolve the same error for more than 5 days, and it's not a problem of configuration, only IOS.
The 12.4T IOS drops the call because of facility information that comes from the PBX, but the mainline IOS doesn't.
Thanks!!
Andres Pasten
Adexus S.A.
2444
