Community Member
ISDN error
I configured E1 isdn line with MGCP gateway.
Now if i call from inside to outside it give fast busy.
Below is the debug isdn q931
VG-2#
Jul 17 07:38:47.381: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0002
        Sending Complete
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838C
                Exclusive, Channel 12
        Calling Party Number i = 0x0081, '126'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '95160290'
Jul 17 07:38:47.413: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8002
        Cause i = 0x829F - Normal, unspecified
VG-2#
thank u
Everyone's tags (2)
Green
ISDN error
Is 95160290 a valid number in your PSTN access
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Community Member
ISDN error
Yes its valid number.....
Re: ISDN error
Your calling number is abnormal which probably causing your teleco to drop the call.
Do proper digit manipulation at CUCM level to reformate the calling number.
Community Member
ISDN error
the number am using for testing is my GSM active number and its working properly...
Is their any possibility that Telco not configured properly to receive such number.
Re: ISDN error
Hi, based on your debugs the calling number sent to teleco is 126 which is definitly not valid and can't be accepted by teleco.
"if you find this post useful, please rate it"
326
