Community Member
ISDN Errror messages.
HI,
I have errors in my c2821 gateway that I do not understand. Can somebody please explain this errors to me. I have search around but have not found any answer.
200722: Nov 26 13:06:43.961: ISDN Se0/0/1:15 SERROR: process_pri_simple: NO name
in GTD
200723: Nov 26 13:06:43.961: ISDN **ERROR**: Module-CCPQSIG Function-CCPQSIG_C
allConnected Error-Unknown event 0x58
200724: Nov 26 13:06:46.621: ISDN Se0/0/1:15 SERROR: process_pri_simple: NO name
in GTD
200725: Nov 26 13:06:46.625: ISDN **ERROR**: Module-CCPQSIG Function-CCPQSIG_C
Per
Bronze
Re: ISDN Errror messages.
It seems the application was trying to send INFO message after the connection already established. Coul dyou provide the details of these debugs:
debug isdn q931
debug isdn q931 detail
debug isdn event
debug isdn event detail
Community Member
HI,
This is a part of my debug output. It did not helped me to understund the *ERROR* and SERROR messages.
Q931d: L3_state_change: callref 0xA
426 old RELEASE_REQUEST, new NULL_STATE
471126: Dec 4 14:22:16.388: ISDN Se0/0/0:15 Q931d: CC_CHAN_GetUserpri: using ca
ll_id = 0x3BC1
471127: Dec 4 14:22:16.388: ISDN EVENTd: cc_clear_free_list freed 0x669083B8
471128: Dec 4 14:22:16.388: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid
1/0x3BC1 calltype 2 CALL_CLEARED
471129: Dec 4 14:22:16.388: ISDN Se0/0/0:15 EVENTd: calltrkr_call_cleared: isdn
_info=0x663E2650, call_id=0x3BC1
471130: Dec 4 14:22:16.388: ISDN Se0/0/0:15 EVENTd: calltrkr_call_cleared: isdn
_info=0x66429910, call_id=0x3BC1
471131: Dec 4 14:22:16.388: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, Connec
tionId F95AA93E A1AA11DC BBC10012 80132C20, SetupTime 15:21:01.428 met Tue Dec 4
2007, PeerAddress 702969152, PeerSubAddress , DisconnectCause 10 , DisconnectT
ext normal call clearing (16), ConnectTime 15:21:06.008 met Tue Dec 4 2007, Disc
onnectTime 15:22:16.328 met Tue Dec 4 2007, CallOrigin 2, ChargedUnits 0, InfoTy
pe 2, TransmitPackets 3514, TransmitBytes 590352, ReceivePackets 3515, ReceiveBy
tes 562400
471132: Dec 4 14:22:16.832: ISDN Se0/0/1:15 EVENTd: process_pri_simple: msg 88,
call id 0xE755, bchan 16, call type VOICE
471133: Dec 4 14:22:16.832: ISDN Se0/0/1:15 SERROR: process_pri_simple: NO name
in GTD
471134: Dec 4 14:22:16.832: ISDN Se0/0/1:15 EVENTd: process_pri_simple: Packet
to CC Data: 58 1 1 E7 55 0
471135: Dec 4 14:22:16.832: ISDN **ERROR**: Module-CCPQSIG Function-CCPQSIG_C
471136: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8 callref =
0x064B
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Progress Ind i = 0x8583 - Origination address is non-ISDN
Progress Ind i = 0xA190 - Reserved value
Calling Party Number i = 0x1181, '34935140900'
Plan:ISDN, Type:International
Called Party Number i = 0xC9, '77277'
Plan:Private, Type:Subscriber(local)
User-User i = 0x00FE, 'U', 0x0100, 'Y', 0x0100B4
Shift to Codeset 5
Codeset 5 IE 0x31 i = 0x81
Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x80
471137: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931d: L3IF_rx_L2_pak: received dat
a
471138: Dec 4 14:22:16.988: 0802064B0504039090A31803A183811E
471139: Dec 4 14:22:16.988: 0285831E02A1906C0D11813334393335
471140: Dec 4 14:22:16.988: 3134303930307006C937373237377E09
471141: Dec 4 14:22:16.988: 00FE550100590100B49D3101819D3201
471142: Dec 4 14:22:16.988: 80
471143: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931d: L3_Go: source = 0x20A, event
= 0x5, call id = 0x0, int id = 0x0
471144: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931d: L3_Go: event 0x5 cr_len 2 c
r 34379
471145: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931d: L3_state_change: callref 0x0
000 old UNKNOWN_STATE, new NULL_STATE
471146: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931d: L3_Go: call_id 0x0 cr 0x864B
state 0 event 0x5 ces 1
471147: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931d: L3_ProcessEvent: callref = 0
x864B SETUP:U0_Setup(nlcb)
471148: Dec 4 14:22:16.988: ISDN Se0/0/1:15 Q931d: L3_state_change: callref 0x0
000 old NULL_STATE, new UNKNOWN_STATE
471149: Dec 4 14:22:16.988: ISDN Se0/0/1:15 EVENT: process_rxstate: ces/callid
1/0x3BC4 calltype 2 CALL_INCOMING
471150: Dec 4 14:22:16.988: ISDN Se0/0/1:15 EVENTd: isdn_get_guid: Got Guid 266
4AAE9BBC4
471151: Dec 4 14:22:16.988: ISDN Se0/0/1:15 EVENT: call_incoming: call_id 0x3BC
4, Guid = 2664AAE9BBC4
Community Member
You should use a graphical tool to look at your debugs, like the pri debugger at pippinsoftware.com - you can download the demo for free, the full version comes out in Jan '08
Community Member
The first beta of this PRI debugger had some issues, there's a revised beta posted at pippinsoftware.com now.
aqnyone ever figure out the solution, I have these error's now, and I think this is my problem!
Cheers,
Chad
Community Member
hi,
Can you get me the outputs of
debug isdn q931
debug isdn events
After enabling the mentioned debug commands,you need to fire the isdn number by using the below command
isdn test call int bri x/x/x
fire this command twice and capture the logs and output of
sh is st
sh is ac
sh call history
Siva
702
