Community Member
ISDN handset ring
I have an ISDN handset connected to a VIC2-2BRI-NT/TE card.
Have dial tone and can place calls to other Voip on my system.
I have created a dial peer with destination pattern 250.
If a call a voip phone it flags the call as comming from 250. If I dial 250 on the VoIP phone my ISDN handset doesn't ring but the VOip phone says its connected.
How can I make the handset ring so I can answer the call?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: ISDN handset ring
Good. Now if you want the correction extension to show for calls made from the isdn phone, configure station number under the voice port.
Useful post? Then rate it using the scrollbox below!
Hi Martin,
Sometime ISDN phones have strange ways of taking calls. I have one in the office that when rang, sends 'release' before answering!
So please enable "term mon" and "debug isdn q931" to see what happens. The phone also may want to see the called number so why don't you try 'forward-digits all' under the DP.
Community Member
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
line-power
voice-port 0/0/0
compand-type a-law
cptone GB
description Configured for ISDN handset
dial-peer voice 10 pots
destination-pattern 650372
port 0/0/0
Theres my config all of a sudden it kicked in. Don't understand. Yet again I don't change anything then it starts working. Very weird
Thanks for your advise anyway
118
