Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ISDN Hardware - PSTN Gateway
What would be the correct Hardware to connect:
AN E1 ISDN Connection to be terminated on a HDSL modem and then to a CIsco Router - WIC-2MFT-G703/WIC-2MFT-E1 OR Cisco E1/T1 ISDN PRI Network Module or something else???
Hall of Fame Super Gold
Re: ISDN Hardware - PSTN Gateway
Hi, which router model do you have ?
3845 running IOS 12.11(T)
Hi, if no PVDM2-xx in the box (do show diag to know), you need VWIC-1MFT-E1 or VWIC2-1MFT-1E1/T1, and a PVDM2-32 to support full 30 channels, or a smaller PVDM2 size like 16 or 8.
Thanks for the rating and good luck!
yes, there is a PVDM2-64 installed, will a VWIC-2MFT-G703 work for this as well?
Will a VWIC-2MFT-G703 work for Connection of ISDN E1 T2 Fibre line???
Yes. Your telco will present an E1 interface to which you connect the router.
Note, you don't need, the G.704 version that is used only when unframed is desired. The basic vwic or vwic2 is enough.
351
