ISDN issue - network-clock-participate??
mnour401917_2
Hi all,
I have an issue with the following command on a new Cisco 2821 router.
network-clock-participate wic 2
when I try to add this command to the router it comes with the following error
WIC slot is empty or does not support clock participate
Any idea? Thanks!
Nour
CCME#show telephony-service
CONFIG (Version=7.0(1))
Version 7.0(1)
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
CCME# show diag
WIC Slot 2:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : B0
Deviation Number : 94603
Fab Version : 04
PCB Serial Number : FOC121019VG
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
0x10: 42 42 30 88 00 01 71 8B 02 04 C1 8B 46 4F 43 31
0x20: 32 31 30 31 39 56 47 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
CCME#show ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 00:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
SC_2821-CCME uptime is 1 week, 6 days, 10 hours, 51 minutes
System restarted at 07:31:29 WST Wed Apr 29 2009
System image file is "flash:c2800nm-adventerprisek9-mz.124-22.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 237568K/24576K bytes of memory.
Processor board ID FTX1246A05Z
2 Gigabit Ethernet interfaces
1 ATM interface
1 terminal line
1 Channelized (E1 or T1)/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
255488K bytes of ATA CompactFlash (Read/Write)
CCME#
Brandon Buffin
Try entering the following command first:
router(config)#card type t1 1
This is assuming this is a T1 and not an E1.
Hope this helps.
Brandon
