ISDN Layer 1 shutdown on Channelized E1
I have a problem on a customer site.
He had a E1/PRI trunk on an Alcatel PABX.
I just installed a Cisco 2921, with the same conf as another site I have deployed.
When I connect the E1 on the 2921, layer 1 doesn't go up, even with a CUCM MGCP config (with is a copy/paste of the another site too).
If i try a show isdn status I obtain the following message :
GW-2921-***#show isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
SHUTDOWN
    Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 1
    Total Allocated ISDN CCBs = 0
The card is a VWIC3-1MFT-T1/E1.
Here is a part of the 2921 conf, complete is on attachment :
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
isdn voice-call-failure 0
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/0:15
echo-cancel coverage 64
cptone FR
Please help, because "shutdown" state on layer 1 is'nt very referenced
1 ACCEPTED SOLUTION
VIP Purple
Hi Bonnal,
Please check whether you are using correct pairs i.e 1,2 and 4,5 on VWIC side.
If yes, please try swapping them.
regds,
aman
I'd start by making sure you're using the right cable, and the cable works fine.
Who is emulating telco side???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
VIP Purple
Hi Bonnal,
regds,
aman
Jaime : Provider is Completel (in France)
So, pairs are differents if you plug your E1 on an Alcatel PABX, or VWIC Cisco card ?
Do you have a picture to build the connector ?
I have a 2nd provider in standby, it has an SDSL link which comes from MPLS to a OneAcces modem, I try to plug the PRI RJ45 copper straight cable in the VWIC, and it doesn't work too, whereas it works an Alcatel too!
VIP Purple
Crossing pairs solves the problem.
Thank you.
Clement
4601
