07-09-2013 11:45 AM - edited 03-16-2019 06:17 PM
Hi Guys,
I just ran a sh isdn status command on voice gateway & found that layer 2 status is looking weird, Is there anyone who knows, why is that ?
Here is the output:
cpp-vgw-1#sh isdn st
Global ISDN Switchtype = primary-4ess
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI = 0, Ces = 1, SAPI = 63, State = TEI_ASSIGNED
Layer 3 Status:
0 Active La
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 91
07-09-2013 04:54 PM
Mohit,
This looks like an issue with link establisment.
Your Call Manager gateway endpoint and router should have the same isdn switch type
and importantly agree with the switch type of the service provider.
Alex.
Please rate useful posts.
07-10-2013 02:08 AM
Hi Alex,
Yes configuration is just like that.
07-09-2013 09:35 PM
Hi Mohit,
This output you can see during TEI negotiation.
Did you modify any of the configurtaion before layer 2 status comes into active state (i.e. Multiframe established) ?
For confirmation, execute debug q921 command and check if you are still receiving TEI state with SAPI other than 0.
If NO, then the possibility is that the router / gateway has kept the old status in it's pool and appended the new status.
Try to clear counters and reset the link to re-establish the link status and monitor it.
07-09-2013 10:12 PM
Hi Mohit,
Can u share the config/version/inventory of router?
what is CUCM version u are using?
regds,
aman
07-10-2013 02:02 AM
Hi Aman, below is the sh hardware & version output, & CCM version is 7.1.5.
2-rpi-vgw-2#sh hard
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 11:22 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
2-rpi-vgw-2 uptime is 45 weeks, 5 days, 21 hours, 13 minutes
System restarted at 12:10:21 CST Fri Aug 17 2012
System image file is "flash:c3845-adventerprisek9-mz.124-24.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 3845 (revision 1.0) with 746495K/39936K bytes of memory.
Processor board ID FTX1213A1CR
2 Gigabit Ethernet interfaces
124 Serial interfaces
6 Channelized/Clear E1/PRI ports
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
____________________________________________________________
2-rpi-vgw-2# sh version
FYI - I've checked the configuration thrice, but it is looking good, prior to this issue this circuit had been facing issues with Service Provider which is Telefonica.
07-10-2013 02:06 AM
Hi Nishant,
Nope, I did not make any changes myself, & configuration is looking good.
Q921 messages are looking good, & calls are working fine, there is no impact.
I've aleady raised a ticket with SP on this & waiting for their response. (It might be a SP issue)
07-10-2013 02:51 AM
Might be an issue of SP.
Check logs whether you have received any alarm regarding link failure or any kind of fluctuation, because at present as you said there is no any issue in Q921 messages.
07-11-2013 08:00 AM
It has been resolved auto., it was a SP issue but as usual they are still not accepting it. LOLzzz
07-12-2013 08:40 PM
I saw that a couple of times, I found some situations where is a "Cosmetic" bug, usually a reload fix it... Not sure if this is the case, but I'm glad it is resolved now.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
