ISDN line usage report
Can anyone give me a copy of of sql script to have an isdn line usage report?
I think all the tables in CCM4.1 are the same or default?
thanks
Bronze
Re: ISDN line usage report
Why not use ART to generate this information for you? I believe the gateway utilization reports will give you the detail you're looking for.
-- -Mark Turpin
the problem is whenever I run the gateway utilization report, I only "Gateways with zero ports" and no data on it.
Do I need to setup something?
thanks
I was able to resolve it by adjusting the max port of my gateway.
thanks
90
