Community Member
isdn log
help me pls,
I cant perform call from IP Phone on CME to NEC phone after migration on new IOS 15.2.4(M4)
CME      - <sip>  -    CUBE   - <pri> -  NEC
the same config on 12.4(24)T3 working without any problems.
007985: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 85742
007986: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x03DF callID = 0x8360 switch = primary-net5 interface = Network
007987: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x03DF
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Display i = 'TEST'
        Calling Party Number i = 0x0180, '85742'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '1567'
007988: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x03DF
        Cause i = 0x8290 - Normal call clearing
007989: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x83DF
007990: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x83DF
        Progress Ind i = 0x8182 - Destination address is non-ISDN
007991: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x83DF
007992: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x8360, call ref 0x3DF, event 0x2
007993: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x8360, call ref 0x3DF, event 0x1
007994: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8  callref = 0x03DF
        Cause i = 0x80E202 - Message not compatible with call state or not implemented
        Call State i = 0x0C
007995: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8  callref = 0x03DF
        Cause i = 0x80E201 - Message not compatible with call state or not implemented
        Call State i = 0x0C
007996: Feb 18 19:06:32 MSK: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x03DF
1 REPLY
isdn log
If the same config works with 12.X but not with 15.X, then it could be issue of toll fraud application. Please check this url http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/112083-tollfraud-ios.html
//Suresh Please rate all the useful posts.
120
