isdn outgoing ie redirecting-number now working
kuldeep.kaur
Guys,
Situation
R1 ----> PSTN -------R2 (SRST)
When a phone 4001 from site R1 calls Site R2(SRST) phone 5001, when no one answers the phone goes to R1 (4001) voicemail Unity Connection instead of R2 phone (5001) voice mail
I have gone through the web and the support forum and everyone suggesting is use the isdn outgoing ie redirect-number on R2. I have tried that and still it is not working. My routers are running version 15.1 so dont think it is a bug as suggested in some posts.
I have seen this working but not able to get it working in my lab. What am I missing or doing wrong here ? Below are my configs from the router
PSTN Router
interface Serial0/0/0:15 ---> going to R1
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
isdn send-alerting
isdn outgoing display-ie
no cdp enable
interface Serial0/1/0:15 ----> going to R2
description connect-sb
no ip address
encapsulation hdlc
no isdn outgoing display-ie
no cdp enable
PSTN
Sep 17 11:52:29.531: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0025
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Display i = 'HQ Phone 1'
        Calling Party Number i = 0x2181, '4001'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '9723035001'
        Redirecting Number i = 0x000082, '5001'
                Plan:Unknown, Type:Unknown
Sep 17 11:52:29.559: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8025
Sep 17 11:52:29.627: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8025
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Sep 17 11:52:49.663: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x00CA
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Called Party Number i = 0xA1, '4082024220'
Sep 17 11:52:49.691: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80CA
Sep 17 11:52:49.691: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80CA
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Sep 17 11:52:49.699: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x80CA
        Display i = 'VoiceMail'
Sep 17 11:52:49.711: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x00CA
Sep 17 11:52:49.751: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8025
Sep 17 11:52:49.759: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0025
Sep 17 11:52:50.555: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0025
        Cause i = 0x8290 - Normal call clearing
Sep 17 11:52:50.563: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8025
Sep 17 11:52:50.595: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x00CA
Sep 17 11:52:50.599: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0025
Sep 17 11:52:50.639: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x80CA
Sep 17 11:52:50.647: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x00CA
R1 Router
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
isdn outgoing ie redirecting-number <-- I know this command should not be here but I just tried
no cdp enable
R1#
Sep 17 11:54:44.887: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0026
        Sending Complete
                Standard = CCITT
Sep 17 11:54:44.915: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8026
R1#
Sep 17 11:54:44.983: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8026
R1#
Sep 17 11:55:05.019: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x00CC
        Sending Complete
                Standard = CCITT
Sep 17 11:55:05.047: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80CC
R1#
Sep 17 11:55:05.047: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80CC
Sep 17 11:55:05.055: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x80CC
Sep 17 11:55:05.067: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x00CC
Sep 17 11:55:05.111: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8026
Sep 17 11:55:05.115: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0026
R1#
Sep 17 11:55:08.215: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0026
Sep 17 11:55:08.227: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8026
Sep 17 11:55:08.259: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0026
Sep 17 11:55:08.263: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x00CC
Sep 17 11:55:08.299: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x80CC
Sep 17 11:55:08.311: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x00CC
R2 Router
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 142.102.65.254 port 2000
max-ephones 2
max-dn 10
transfer-pattern .T
voicemail 4220
call-forward pattern .T
call-forward busy 4220
call-forward noan 4220 timeout 20
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 152.1.45.254 152.202.45.254
time-zone 8
R2#
.Sep 17 11:56:35.433: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x00CD
        Sending Complete
                Standard = CCITT
.Sep 17 11:56:35.437: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x80CD callID = 0x0029 switch = primary-net5 interface = User
.Sep 17 11:56:35.437: ISDN Se0/0/0:15 Q931: extract_redirect_orig_called_ie: IE type redirecting num 5001 reason 2 cnt -1 plan 0 type 0 pres 0
.Sep 17 11:56:35.469: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80CD
.Sep 17 11:56:35.481: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80CD
.Sep 17 11:56:55.493: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 4001
.Sep 17 11:56:55.497: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00A7 callID = 0x8028 switch = primary-net5 interface = User
.Sep 17 11:56:55.497: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00A7
        Sending Complete
                Standard = CCITT
        Called Party Number i = 0xA1, '14082024220'
.Sep 17 11:56:55.525: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80A7
.Sep 17 11:56:55.573: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80A7
.Sep 17 11:56:55.581: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x80A7
Please help me out guys.
Tks
5 Replies 5
kuldeep.kaur
Guys the heading is wrong. It should be
Isdn outgoing ie redirecting-number not working.
Pls someone have a look and reply to me. Tks
You need to change how unity connection select mailboxes. The default is that it uses first redirecting number (which is 4001)..What you want is to change it to last redirecting number..
To change the setting login to unity connection admin...then scroll down to
Advanced>conversations>
Use Last (Rather than First) Redirecting Number for Routing Incoming Call (you need to tick the box)
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi there,
I have changed the settings as per your instructions. The only difference now i can see on R1 phone that the voicemail number is changed to 5001 and that is correct but it still goes to voice mail of R1 and not R2. Any more suggestions pls.
Tks
Are you using CUCM? If you are, check the call routing information..inbound calls..tick the box Redirecting Number IE Delivery - Inbound
Test again
HI there,
Yes I am using CUCM and Redirecting Number IE Delivery Inbound and outbound is already ticked.
Tks
