ISDN PRI b-channel selection
Dear Experts,
Is it possible to send outgoing call via particular b-channel on PRI ISDN interface ?
I tried to configure that like destination pattern in pots dial-peer with configured trunk group which should be bonded to approprite b-channel/serial iface, but b-channels for some reason are not accessible on my platform like below:
controller E1 2
framing CRC4
clock source line primary
pri-group timeslots 1-31
interface Serial2:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
no cdp enable
dial-peer voice 1 pots
huntstop
destination-pattern1#.....$ -- b-channel #1
trunkgroup ch1
router(config)#inter serial 2:1
% Cannot access B-channel interfaces
router(config)#
Is what I want possible in principle or I can only use Asc/Desc/RR selection ? The platform is:
router#sh ver
IOS (tm) 5300 Software (C5300-IS-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Thanks and best regards
Alex
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: ISDN PRI b-channel selection
Are you sure that this channel bank supports PRI, and not E1 R2 instead ?
And even if it supports PRI only, can't you configure it so thjta calling different numbers, different ports are used ?
Why you think you need to select the channel to use?
Remote device receiving calls is custom made non-configurable E1 -> FXO "converter" with hardware routing logic i.e. to reach terminal connected to say FXO #2 I need to send call via b-channel #2
I think so. When I configure pri-group timeslots 1-1,16 in e1 controller my call comes out of FXO1 as expected.
The box has only E1 port and 30 FXO ports and is not configurable.
Cheers / Alex
Thanks for claryfing.
I'm afraid that IOS is too old to support controller-level trunk-group. You might need to upgrade hardware for that to work.
You can use the trunk-group command within the controller to group timeslots and then point to the trunk groups from the dial-peers. Eg:
Router(config)# controller T1 0
Router(config-controller)# pri-group timeslots 1-24 nfas_d primary nfas_int 0 nfas_group 0
Router(config-controller)# trunk-group L1 timeslots 1-5 preference 1
Router(config-controller)# trunk-group L2 timeslots 12-14 preference 2
Router(config-controller)# exit
Router(config)# controller T1 1
Router(config-controller)# pri-group timeslots 1-24 nfas_d backup nfas_int 1 nfas_group 0
Router(config-controller)# trunk-group L3 timeslots 1-5
Router(config-controller)# trunk-group L4 timeslots 12-14 preference 4
For more information search for "timeslots" in the "Command Lookup Tool" page here:
http://tools.cisco.com/Support/CLILookup/cltSearchAction.do
thanks, but seems not compatible with globally set primary-net5 switch type:
router(config)# controller e1 0
router(config-controller)#pri-group timeslots 1-31 nfas_d primary nfas_int 0 nfas_group 0
%ISDN NFAS only supported for primary-4ess, primary-dms100, primary-ni and primary-ntt switch-types set globally.
Michael, I've tried your config on the spare unit (same hw) - this time with cas-compatible switch type, but no luck again:
isdn switch-type primary-ni
controller E1 0
framing CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 0 nfas_group 0 <-- accepted this time
router(config)#contr e1 0
router(config-controller)#trun?
% Unrecognized command
router(config-controller)#?
Controller configuration commands:
  cablelength       cable length for a DS1 link
  cas-custom        cas group customization configuration
  channel-group     Specify the timeslots to channel-group mapping for an interface
  clock             Specify the clock source for a DS1 link
  default           Set a command to its defaults
  description       Controller specific description
  ds0               ds0 commands
  ds0-group         Configure group of timeslots to a particular signaling type
  exit              Exit from controller configuration mode
  extsig            Configure an external signalling protocol - { mgcp }
  framing           Specify the type of Framing on a E1 link
  guard-timer       Guard timer (0-20) for xcsp calls - timer duration and accept/reject on expiry
  help              Description of the interactive help system
  line-termination  Specify the line termination for E1
  linecode          Specify the line encoding method for a E1 link
  loopback          Put the entire E1 line into loopback
  no                Negate a command or set its defaults
  pri-group         Configure the specified timeslots for PRI
  shutdown          Shut down a E1 link (send Blue Alarm)
  voice-class       specify a voice class
don't see trunk-group command here - there's a channel-group command, but with defined pri-group it gives no effect.
Green
Can you try this
trunk-group BOB
trunk-group BILL
controller E1 2
framing CRC4
trunk-group BOB timeslots 1
trunk-group BILL timeslots 2-31
no ip address
encapsulation hdlc
no cdp enable
huntstop
trunkgroup BOB
Alex
Regards, Alex. Please rate useful posts.
Hi Alex !
Here's sh runn output:
trunk group  bob
trunk group  bill
controller E1 0
framing CRC4
interface Serial0:15
no ip address
encapsulation hdlc
no cdp enable
then I do:
router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
router(config-controller)#trun? <-- OK, maybe it's hidden command - lets do comlpete input:
router(config-controller)#trunk-group bob timeslots 1
% Invalid input detected at '^' marker.
router(config-controller)#trunk-group bill timeslots 2-31
  ds0               ds0 commands
trunk-group command is not among options...
Thanks / Alex
2575
