ISDN PRI configuration on 2800 Problem
jordan.bean
We've been using MGCP w/D channel backhaul in the past with no problems. I'm now trying to configure a Cisco 2851 with a PRI using H.323. I can't figure out why my POTS dial peer is showing "down" on "OUT STAT".
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
1 voip up up ....... 1 syst ipv4:10.10.10.10
2 voip up up ....... 2 syst ipv4:10.10.10.11
10 pots up up .T 0 down 1/0:23
PRI Channel Statistics:
ISDN Se1/0:23, Channel [1-24]
Configured Isdn Interface (dsl) 0
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3
Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface Serial1/0:23
description PRI
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
dial-peer voice 1 voip
preference 1
destination-pattern .......
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.10
incoming called-number .
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.11
no vad
dial-peer voice 10 pots
destination-pattern .T
direct-inward-dial
port 1/0:23
forward-digits all
Any help would be greatly appreciated.
Ayodeji Okanlawon
Can you post the output of your sh isdn status and sh ip interface brief
Please rate all useful posts
XXX-2851#show isdn status serial 1/0:23
Global ISDN Switchtype = primary-4ess
ISDN Serial1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
BOA-2851#show ip interface brief
GigabitEthernet0/0 172.26.3.1 YES NVRAM up up
GigabitEthernet0/1 172.26.4.1 YES NVRAM up up
Serial0/1/0 unassigned YES NVRAM up up
Serial0/2/0 unassigned YES NVRAM down down
Serial0/3/0 unassigned YES NVRAM up up
Serial1/0:0 unassigned YES unset down down
Serial1/0:1 unassigned YES unset down down
Serial1/0:2 unassigned YES unset down down
Serial1/0:3 unassigned YES unset down down
Serial1/0:4 unassigned YES unset down down
Serial1/0:5 unassigned YES unset down down
Serial1/0:6 unassigned YES unset down down
Serial1/0:7 unassigned YES unset down down
Serial1/0:8 unassigned YES unset down down
Serial1/0:9 unassigned YES unset down down
Serial1/0:10 unassigned YES unset down down
Serial1/0:11 unassigned YES unset down down
Serial1/0:12 unassigned YES unset down down
Serial1/0:13 unassigned YES unset down down
Serial1/0:14 unassigned YES unset down down
Serial1/0:15 unassigned YES unset down down
Serial1/0:16 unassigned YES unset down down
Serial1/0:17 unassigned YES unset down down
Serial1/0:18 unassigned YES unset down down
Serial1/0:19 unassigned YES unset down down
Serial1/0:20 unassigned YES unset down down
Serial1/0:21 unassigned YES unset down down
Serial1/0:22 unassigned YES unset down down
Serial1/0:23 unassigned YES manual up up
Layer 2 needs to say MULTIPLE_FRAME_ESTABLISHED. Do term mon and debug isdn q921 and see what the output is and post it.
Hope that helped, if so please rate.
