02-19-2007 03:52 AM - edited 03-14-2019 08:05 PM
Hi all,
I have VWIC2-2MFT-T1/E1 in my voice gateway (2821). These are configuration on provider's side :
- isdn switch type Euro
- framing no-crc4
- linecode hdb3
- network side
- d-channel 16
- timeslots 1-31
Here is my configuration :
network-clock-participate slot 1
network-clock-select 1 e1 1/0
isdn switch-type primary-net5
controller e1 1/0
framing no-crc4
linecode hdb3
pri-group timeslots 1-31
no shut
int s1/0:15
isdn incoming-voice voice
no shut
So far, the link is always up and down. I see that layer 2 is sometimes up before get RAI or LOF detected message and down. Cisco documentation said to try loopback test and change another port. I have tried both of them, but still can't find solution. The provider said that they use Lucent on their device. does anyone experience with Lucent and Cisco compatibility ? See attached file on debug events, debug isdn q921, and debug q931.
suwa
Solved! Go to Solution.
03-26-2007 10:29 PM
An unhappy event showed up a few days after being stable. Yes! the link went flapping again. After searching it for weeks, finally I got (from my senior) a TAC Case looked alike with my case. It said that the module had to be configured as normal mode. The default of my card was wetting current mode. Since turning to normal mode, issue has been solved. Just check it:
http://www.ciscotaccc.com/voice/showcase?case=K84133319
Hope this post able to help others with the same case.
Regards.
03-27-2007 06:14 AM
Good info, thanks! Regards to the senior.
